stereo wiring information
Welcome Guest :)
dadstut
Member -
Posted: January 02, 2008 at 7:09 AM / IP Logged
I am searching for this information for a 1999 Suzuki Vitara (base model).
KarTuneMan
Platinum -
Posted: January 05, 2008 at 10:00 AM / IP Logged
| 12 VOLTS | WHITE/ green | On junction block under dash | + |
| | | The ignition switch wires extend down the steering column, across to the junction block above the driver's kickpanel. The wires are located in a large GRAY connector. |
| IGNITION | BLACK/ white | On junction block under dash | + |
| ACCESSORY | Yellow/black | On junction block under dash | + |
| STARTER | BLACK / YELLOW | On junction block under dash | + |
| KEY SENSE | Blue/red | Ignition switch harness | + |
| TACH SIGNAL | See notes | | |
| | | On the 2.5L the BROWN tach wire is located at pin-4 on the 35-pin connector on the ECM behind the glovebox (6 cylinder signal). On the 1.6L and 2.0L the BROWN tach wire is at pin-6 of the 35-pin connector on the ECM (4 cylinder signal). |
| FUEL INJECTOR | Opposite from Blue/black | At any injector on engine | AC |
| LOCK | Pink | Above driver's kickpanel | - |
| | | In a BLUE connector on the left side of the junction block. |
| UNLOCK | Pink/green | Above driver's kickpanel | - |
| DOORPIN | BLACK/ red | In a white plug below fuses | - |
| TRUNK PIN | Common with doors | | |
| BRAKESWITCH | GREEN / WHITE | At junction block above DKP | + |
| | | In a 20-pin WHITE connector. |
| PARKLIGHTS | RED / yellow | At junction block above DKP | + |
| | | In a 18-pin WHITE connector. |
| HAND BRAKE | Violet/white | At DRL module on right of st. column | - |
Sunday, April 19, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
