2004 ram quad cab 3500, stereo wiring
blakelpd5
Posted: January 05, 2008 at 7:02 PM / IP Logged
I looked at the wiring diagrams in the database, but none of the colors match the wires in my stock harness.  I see a note at the bottom saying something about it could be different for 2500 and 3500 models.   Help please?
blakelpd5
Posted: January 05, 2008 at 7:28 PM / IP Logged
I guess I should let you know what I am trying to do.  I am trying to get a line output off the stock stereo so I can hook up an amp and subs.   Sorry for the two posts.
**admin edit: changed to 2004 ram quad cab 3500, stereo wiring**
blakelpd5
Posted: January 06, 2008 at 8:41 PM / IP Logged
Ok, so I looked thru all the years, and finally found one that looked like it had the same color wires as mine, and it worked...  It is a single connector with two rows on it, and here is the link to the correct one.  This site is a great resource.  https://www.the12volt.com/installbay/forum_posts.asp~TID~54234
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
