2008 Nissan Titan, Alarm/Remote Start Wiring
TJ92Civic
Copper - Posts: 161
Posted: January 23, 2008 at 11:19 AM / IP Logged
Anyone have the wiring diagram for a 2008 Nissan Titan? Thanks. Or is it the same as an 07?
KarTuneMan
Platinum - Posts: 7,056
Posted: January 23, 2008 at 8:06 PM / IP Logged
12 VOLTS Green Ignition Harness   +
 IGNITION BLACK/ Red Ignition Harness   +
 ACCESSORY Red Ignition Harness   +
 STARTER Brown Ignition Harness   +
 STARTER 2 Lt.Green Ignition Harness   +
 KEY SENSE RED / blue Ignition switch harness   +
 TACH SIGNAL SEE NOTES    AC
 This vehicle has independent coils, there are three wires per coil, WHITE/ Blue, Black and the third is the tach signal wire.
 FUEL INJECTOR Opposite of White At any injector on engine   AC
 LOCK Blue At switch inside driver's door   -
 You must run wires into the doors to connect to these wires. The first pulse on the RED will disarm and a double pulse will unlock the doors.
 UNLOCK Red At switch inside driver's door   -
 DOORPIN SEE NOTES
 Driver's door is LT.BLUE, front passenger door is RED / BLUE. The left rear door is RED / YELLOW and the right rear door is RED / WHITE. All 4 wires are (-) and found at the BCM on the right side of the steering column.
 R.A.P. SHUT DOWN Lt.Blue SEE NOTES   -
 This vehicle is equipped with automatic headlights that will stay on after a remote shutdown.you must pulse the drivers doorpin wire to shut the lights off. Drivers doorpin is Lt.Blue at BCM on right side of steering column.
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire
 BRAKESWITCH RED / Green At brake switch   +
 PARKLIGHTS RED / Blue At dimmer switch   +
 HAND BRAKE Green At switch on handbrake lever   -
 HORN RED / White At steering column harness   -
 VSS WIRE WHITE/ red Behind instrument panel   AC
TJ92Civic
Copper - Posts: 161
Posted: January 24, 2008 at 12:01 PM / IP Logged
Thank you! I wonder how much of a pain it's going to be to get to the lock wires in the door...
TJ92Civic
Copper - Posts: 161
Posted: January 24, 2008 at 12:32 PM / IP Logged
This means that I will need to connect the pulse after shutdown (Prestige APS -620) to the driver's doorpin correct? Sorry I am a little bit rusty.
TJ92Civic
Copper - Posts: 161
Posted: January 24, 2008 at 12:36 PM / IP Logged
And this will require the (-) Pulse during crank (Black / Yellow) to be used with a relay correct?
Again sorry for all the questions.
KarTuneMan
Posted: January 24, 2008 at 1:12 PM / IP Logged
Yes.... this will (of course) simulate opening the door.
If your unit has a negative starter output, yes, use this with a relay to do second starter. If iot does not, you can use the main starter output to trigger the relay for second.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
