2002 dodge grand caravan sport
livewire65
Posted: February 17, 2008 at 9:47 AM / IP Logged
I hope I am doing the right forum and the right location.  I recently purchased a '02 Dodge Grand Caravan Sport it did not come with the rke option (Remote Keyless Entry). The Dealer said it was a $300 and up to $500 option. like no way am I going to spend that kind of cash. so here is the big question... I already have the Autopage RF-315 and just a couple of day's ago bought the Chilton manual for it. I have seen a post which includes some wiring cconfigurations but I am really confused at this point, according to my alarm connection(s) I have a 3 pin +/- pulse connector which makes need at least (2) 30amp spst relays there are 4 doors. could someone help me with this I don't want to burn up my bcm as they start at $200 and up.
Doors automatically lock in gear at 20 mph
techman93
Silver - Posts: 591
Posted: February 17, 2008 at 1:46 PM / IP Logged
Most caravans have a single wire door lock system with different resistance to lock and unlock.
5.3 k ohms will unlock and 2.0 k ohms will lock. Violet/dark green (-) with 2 relays wired to ground with each relay having each own resistance wired to the door lock/unlock wire.
diagram from audiovox site
http://documents.audiovox.com/700649.pdf
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
livewire65
Posted: February 17, 2008 at 4:12 PM / IP Logged
Thanks Techman97.
Would you know where to find the hatch trigger so I can connect the theater interior lights?
I am only assuming this vehicle does not have a electrical hatch release since there is no button to push anywhere on the inside.
livewire65
Posted: February 17, 2008 at 4:15 PM / IP Logged
sorry I ment to say techman93 but i guess my finger hit he wrong key and after you hit post it won't let you edit your post.
livewire65
Posted: February 18, 2008 at 8:32 PM / IP Logged
Here is a picture of another diagram...why wouldn't this one work, I like the idea of having only one constant input not two where they have to cross and a waste of wire.
http://www.bulldogsecurity.com/New%20Wires/New%20Wires/Wires/images/2001chrymvlocks.htm
