2007 mdx, alarm/remote start wiring
bozkapro
Posted: February 27, 2008 at 1:28 PM / IP Logged
I am looking for the wiring info on a 2007 Acura MDX  to install alarm/remote starter. Thank you
KarTuneMan
Platinum - Posts: 7,056
Posted: March 02, 2008 at 7:17 PM / IP Logged
Thats such a nice rig......
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Contact your interface module provider to find out if a bypass kit is available.
 12 VOLTS white (50A) ignition harness   +
 IGNITION pink ignition harness   +
 ACCESSORY orange ignition harness   +
 STARTER yellow ignition harness   +
 KEY SENSE pink steering column harness   -
 TACH SIGNAL any ignition coil or fuel injector    ac
 LOCK pink door lock switch in driver door   +
 UNLOCK red door lock switch in driver door   +
 DRIVER LOCK MOTOR brown fuse box, green 12 pin plug, pin 12   5wi
 DRIVER UNLOCK MOTOR gray fuse box, green 12 pin plug, pin 2   5wi
 DOORPIN see notes driver's kick panel   -
 left front, dark green right front, light green left rear, dark green right rear, gray
 HOODPIN green hoodpin switch in latch   -
 TRUNK PIN lt. green rear fuse box, green 42 pin plug, 6th pin   -
 TRUNK RELEASE brown and white fuse box, green 12 pin plug, pins 18, 6
 FACTORY ARM lt. blue driver door key cylinder switch   -
 can also be used to lock car
 FACTORY DISARM dark blue driver door key cylinder switch   -
 can also be used to unlock car
 BRAKESWITCH lt. green white 45 pin plug in the fusebox, 21st pin   +
 PARKLIGHTS gray driver's kick panel   +
 PARKLIGHTS (-) brown headlight switch in column cover   -
 HAND BRAKE orange white 45 pin plug in the fusebox, 44th pin   -
 HORN orange steering column harness   -
