04 dodge ram srt 10 vss location
lees a.b.c.
Posted: March 04, 2008 at 10:23 AM / IP Logged
Hi, I'm trying to hunt down the speedometer pulse wire in a 04 dodge ram 1500 srt-10. Color combo and location?
Thanks in advance.
techman93
Silver - Posts: 591
Posted: March 05, 2008 at 8:56 PM / IP Logged
Off Rostra website
2004 DODGE RAM TRUCK
CRUISE CONTROL
Part # 250-1223
Control Lever: 250-3421,250-3742
Adapter: 250-4369 SIGNAL ADAPTER NOT NEEDED WITH MANUAL TRANS.
VSS Wire: LOCATION 11 4 CONNECTOR ECM- RIGHT GREEN CONNECTOR POSITION 32, MANUAL 3 CONNECTOR ECM BLACK CONNECTOR POSITION 13
VSS Wire Color: AUTOMATIC LT. GREEN / WHITE or GREEN/ BROWN, MANUAL WHITE/ ORANGE or GREEN/ YELLOW
VSS Pulse: AUTOMATIC 38,600 MANUAL 8000
VSS Tach Wire: IF MANUAL TRANSMISSION USE CLUTCH SWITCH 250-4206
Tach Signal Wire Color: WHITE/ BLACK
Brake Switch Positive: PINK/BLUE
Brake Switch Negative: WHITE/ TAN
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
