wiring 8 subwoofers?
mrxzuberant
Posted: April 05, 2008 at 2:12 AM / IP Logged
i need help wiring 8( yes eight) - 2ohm dvc subwoofers.....tryn to see if i can get to run with my 2ohm mono amp.....any help would be much appreciated!! thnx
Platinum - Posts: 13,726
Posted: April 05, 2008 at 4:51 AM / IP Logged
Piece of cake. Wire each 4 of your speakers as shown in the following picture. To
Duplicate for the other 4 speakers
After doing both sides of your box, you will then have one speaker wire for left and one for the right woofers. Connect the left negative wire to the right positive wire and insulate it. This will leave the left positive and the right negative wire. Connect these 2 wires to the appropriate terminals of your amp. Use an ohm meter to test the resistance of the speakers before connecting to the amp.
mrxzuberant
Posted: April 05, 2008 at 11:55 AM / IP Logged
thnks for the help
