2008 Chevrolet Silverado, Alarm/RS Wiring
iwirem00
Posted: April 05, 2008 at 2:21 AM / IP Logged
I am looking for a wiring diagram/cheat sheet for installing an alarm/remote start/door locks in  a 2008 Chevrolet Silverado. Any help is appreciated, thank you
iwirem00
dtk1
Copper - Posts: 179
Posted: April 05, 2008 at 8:45 AM / IP Logged
that car is simple to do it has pk3 so you need an immobilizer bypass
i would recomend you 1701G by directed would do door lock and bypass
WIRE          COLOR          POLARITY          LOCATION
     Battery          RED / WHITE          (+)          IGNITION SWITCH HARNESS
               LOW CURRENT, FOR HIGH CURRENT USE RED / BLACK AT VEHICLE FUSE BOX
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BROWN          (+)          IGNITION SWITCH HARNESS
               MAY BE YELLOW ON SOME MODELS
     Accessory 2          PINK/BLACK          (+)          IGNTION SWITCH HARNESS
               FOR REMOTE START INTEGRATION
     Starter 1          YELLOW/BLACK          (+)          AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT
               NOT FOR REMOTE START, FOR REMOTE START INFORMATION
     Starter 2          PINK/BLACK          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSKEY III® ANTI-THEFT SYSTEM
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          PINK          (+)          IGNITION SWITCH HARNESS
     Tachometer          WHITE          (-)          AT IGNITION COIL
     Speed Sense          YELLOW/BLACK          (AC)          AT ECM MODULE UNDER HOOD ON DRIVER FENDER
               BLACK PLUG PIN #57
     Parking Lights          LIGHT BLUE          (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          LIGHT BLUE/WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
               IGNITION MUST BE ON FOR THIS WIRE TO TEST
     Reverse Lights          DARK BLUE          (+)          AT BCM MODULE UNDER DRIVER DASH
     Horn          TAN          (-)          IN HARNESS AT STEERING COLUMN
ALSO AT BCM MODULE UNDER DRIVER DASH
     All Door Trigger
               MUST USE ALL TRIGGERS AND DIODE ISOLATE EACH WIRE
     Domelight Super          GRAY          (+)          AT BCM MODULE UNDER DRIVER DASH
     LF Latch          GRAY/BLACK          (-)          AT MODULE IN DRIVER DOOR
     RF Latch          TAN/WHITE          (-)          AT MODULE IN PASSENGER DOOR
               MAY BE BLACK/ WHITE ON SOME MODELS
     Hood Trigger          PINK/BLACK          (-)          AT BCM MODULE UNDER DRIVER DASH
               BLACK PLUG PIN #17, NOT ON ALL MODELS
     Alarm Disarm          LIGHT GREEN          (-)          AT MODULE IN DRIVERS DOOR
iwirem00
Posted: April 05, 2008 at 9:06 AM / IP Logged
Is the 1701g hard to program? can i do it my self? thank you for all your help.
iwirem00
