2008 kia sportage
Welcome Guest :)
dannyboy0115
Member -
Posted: April 16, 2008 at 1:50 AM / IP Logged
Im installing a keyless entry to my 2008 Kia Sportage and im looking for the wiring diagram for it. Can anyone help or is the wiring the same as a 2007
kola7126
Copper -
Posted: April 16, 2008 at 2:29 PM / IP Logged
| MODEL | YEAR(S) |
| SPORTAGE | 2005 -2008 |
| KEY | T-HARNESS | IMMOBILIZER |
| N/A | N/A | KIA'S TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 Bypass Module and extra Ignition Key |
| PART | COLOR | LOCATION |
| 12 VOLT CONSTANT | WHITE (+) and RED (+) | IGNITION SWITCH HARNESS |
| STARTER | GREEN (+) | IGNITION SWITCH HARNESS |
| STARTER 2 | N/A | |
| IGNITION 1 | BLUE (+) | IGNITION SWITCH HARNESS |
| IGNITION 2 | N/A | |
| IGNITION 3 | N/A | |
| ACCESSORY /HEATER BLOWER 1 | ORANGE (+) | IGNITION SWITCH HARNESS |
| ACCESSORY /HEATER BLOWER 2 | PINK (+) | IGNITION SWITCH HARNESS |
| KEYSENSE | N/A | |
| PARKING LIGHTS ( - ) | BROWN (-) | @ HEADLIGHT SWITCH |
| PARKING LIGHTS ( + ) | GREEN (+) and GREEN (+) Use both, See NOTE *1 | @ HEADLIGHT SWITCH, See DIAGRAM |
| POWER LOCK | GREEN (TYPE B) | IN DRIVERS KICK PANEL |
| POWER UNLOCK | BLUE (TYPE B) | IN DRIVERS KICK PANEL |
| DOOR TRIGGER | ORANGE (-) | IN DRIVERS KICK PANEL |
| DOMELIGHT SUPERVISION | BROWN (-), Requires Part #775 Relay | @ ETACM Module, 26-pin plug, pin 1, See NOTE *2 |
| TRUNK RELEASE | N/A | |
| SLIDING POWER DOOR | N/A | |
| HORN | BLUE (-) | @ HORN SWITCH |
| TACH | BLUE | @ ECM, See NOTE *3 |
| WAIT TO START LIGHT | N/A | |
| BRAKE | RED (+) | @ SWITCH ABOVE BRAKE PEDAL |
| FACTORY ALARM DISARM | N/A | |
| ANTI-THEFT | TRANSPONDER ANTI-THEFT SYSTEM, REQUIRES 791 BYPASS MODULE AND EXTRA IGNITION KEY | TRANSPONDER @ IGNITION SWITCH TUMBLER |
| EXTRA INFORMATION |
| NOTE *1 this vehicle has (2) PARKING LIGHT wires and will require (2) extra Relays part #775, to connect, See DIAGRAM NOTE *2 the ETACM (Electronic Timing/Alarm Control Module) is located in the CENTER CONSOLE, behind the RADIO and HEATER CONTROL opening. NOTE *3 the ECM (Electronic Control Module) is located on the DRIVERS SIDE FIREWALL, under the HOOD, on the 2.0L, the TACH wire is in PIN 66, on the 2.7L, the TACH is in the 40-pin plug, pin 17. |
dannyboy0115
Member -
Posted: April 18, 2008 at 6:12 PM / IP Logged
Wednesday, April 15, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
