1993 mazda mx3 keyless entry with remote
cyril
Member - Posts: 24
Posted: May 22, 2008 at 12:52 PM / IP Logged
I want to install remote starter with keyless entry in 1993 Mazda MX3 Precidia, It has an alarm system but the wireing specs show n/a.
It has power door locks/keyless entry but the wireing specs say I need to add a actuator in the drivers door. I want to have starter, keyless & alarm system arm/disarm all on the same transmitter.
can anybody give me advise on this? I don't want to do the install until I have more info.
Thanks, Cyril
cyri L. Churchill
kola7126
Copper - Posts: 93
Posted: May 31, 2008 at 2:03 PM / IP Logged
< language=>function printit(){ if (window.print) { window.print() ; } else { var WebBrowser = '< ID="WebBrowser1" width=0 HEIGHT=0 CLASSID="CLSID:8856F961-340A-11D0-A96B-00C04FD705A2">';document.body.insertAdjacentHTML('beforeEnd', WebBrowser); WebBrowser1.ExecWB(6, 2);//Use a 1 vs. a 2 for a prompting dialog box WebBrowser1.outerHTML = ""; }}< language=> var NS = (navigator.appName == "Netscape");var VERSION = parseInt(navigator.appVersion);if (VERSION > 3) { document.write('<>< = value="Print this Page" name="Print" ="printit()">'); } <>< =printit() = value="Print this Page" name=Print>
  MAZDA
 MODEL YEAR(S)
 MX-3  1992 -1996
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  BLACK (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ BLUE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLUE (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLACK/ RED (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GREEN (-)  @ STEERING COLUMN HARNESS
 PARKING LIGHTS ( + ) RED / BLACK (+)  @ DIMMER SWITCH
 POWER LOCK ADD ACTUATOR, See NOTE *1  TO DRIVERS DOOR ONLY, See DIAGRAM
 POWER UNLOCK ADD ACTUATOR, See NOTE *1  TO DRIVERS DOOR ONLY, See DIAGRAM
 DOOR TRIGGER RED / WHITE (-)  @ 3-PIN PLUG, ABOVE FUSES
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN GREEN/ RED (-) or GREEN/ BLACK (-)  @ STEERING COLUMN HARNESS
 TACH YELLOW/BLUE  @ DISTRIBUTOR
 WAIT TO START LIGHT N/A
 BRAKE GREEN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  N/A
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 the FACTORY DOOR LOCK SYSTEM is a CENTRAL DOOR LOCK TYPE, to add KEYLESS ENTRY to this system will require the adding of a DOOR LOCK ACTUATOR Part #742, soem units will also require additional relays part #775, to connect, See DIAGRAMS.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
