2001 Dodge Ram Alarm/Stereo Wiring
johnb268
Member - Posts: 6
Posted: March 08, 2003 at 7:34 PM / IP Logged
hi
my cousin has a 2001 dodge ram 1500 5.9 and is tring to install alarm and the supplied wiring diagram is correct we've looked hi and low everything we found has been pretty much the same as he has. he can't locate the dome light wire and some other wire which i can't remember right now. can someone please help my cousin with a correct wiring diagram
thanks
john b
bivv
Posted: March 08, 2003 at 8:26 PM / IP Logged
www.bulldogsecurity.com go to diagrams.
Platinum - Posts: 12,488
Posted: March 09, 2003 at 4:30 PM / IP Logged
|              12V|red and pink/black  |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|dk. blue            |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|ORANGE / purple *1    |5wi|driver door harness         |
|     POWER UNLOCK|pink/purple *1      |5wi|driver door harness         |
|       LOCK MOTOR|ORANGE / black        |   |driver door harness         |
|     UNLOCK MOTOR|pink/black          |   |driver door harness         |
|    DISARM DEFEAT|no progressive unlck|   |                            |
| PARKING LIGHTS +|BLACK / YELLOW        |   |headlight switch            |
|       HEADLIGHTS|lt. green *5        |-  |headlight switch            |
|     DOOR TRIGGER|yellow *2           |-  |headlight switch or DKP     |
| DOME SUPERVISION|use door trigger    |   |                            |
|  FCTRY ALARM ARM|lt. GREEN/ orange    |*3 |driver door harness         |
|FCTRY ALRM DISARM|same wire           |   |                            |
|       TACHOMETER|BLACK/ gray *4       |   |ignition coil               |
|      SPEED SENSE|WHITE/ orange        |   |C2, pin 27 @ PCM            |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|RED / blk & RED / yel   |+  |steering column             |
|  LF WINDOW UP/DN|lt. blue - white    |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |driver door harness         |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|BLACK/ blue          |-  |radio                       |
|     RADIO SWITCH|RED / white           |+  |radio                       |
| RADIO ILLUMINATE|orange   (dimmer)   |+  |radio                       |
|    POWER ANTENNA|lt green(amp remote)|+  |radio                       |
|       LF SPEAKER|green - brn/red     |   |radio                       |
|       RF SPEAKER|purple - blu/red    |   |radio                       |
|       LR SPEAKER|brn/yel - brn/lt blu|   |radio                       |
|       RR SPEAKER|blu/wht - blu/org   |   |radio                       |
Notes:
*1 Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.  *2 To avoid dome delay, use tan for the drivers door and BLACK/ lt. blue for the passenger door. Both wires are located at the central timer module to the right side of the steering column. Use both wires and diode isolate each.  *3 Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger through a 1.5K (1500) ohm resistor. MUST use relays.  *4 Diesel tach wire is gray/black and diesel wait to start wire is ORANGE / black (-) 'see direct fax document #1090'. Both wires are located on the center of the firewall. There are two black plugs, the wires are in the top plug without the white insert. The tach wire can also be found at the ECM on the passenger side firewall in connector C-1, pin 8. If using the org/blk for wait to start causes a shifting or cruise control problem then use a pulse timer relay instead, refer to directfax #1091 for wiring information.  *5 This wire requires a high current negative, must use relay.
johnb268
Member - Posts: 6
Posted: March 11, 2003 at 6:38 PM / IP Logged
thanks for the help guys.still having problem with dome light after it's hooked up and he arms the alarm he could still open door and not set off alarm could it be that he needs a relay for it to work? my cousin is going to contact the dodge factory for wiring diagram.
again thanks for the help guys
Posted: March 11, 2003 at 7:14 PM / IP Logged
What kind of alarm is it ? Is there a delay in the time that the alarm arms and the time it takes for it engage ?
johnb268
Member - Posts: 6
Posted: March 12, 2003 at 5:00 PM / IP Logged
jeff
the other day he remote started and armed his truck after a minute or so he opened the drivers door and the truck just kept on running if he popped his hood and the truck died and set off the alarm
thanks again
john
johnb268
Member - Posts: 6
Posted: March 12, 2003 at 5:05 PM / IP Logged
jeff
it's delta brand alarm and he has a hood trigger so thats what set off the alarm when he had it running
thanks
john b
Posted: March 12, 2003 at 5:40 PM / IP Logged
Make sure that the wire he used for the door trigger is outputting a (-) signal to the door trigger wire on the Delta alarm. If the door trigger is not sending a ground to the Delta, then you will have to look at the pin switch or the wire itself on the truck.
johnb268
Member - Posts: 6
Posted: March 12, 2003 at 8:45 PM / IP Logged
thanks jeff
i'll tell him that, i'm sure he'll try tomorrow
Posted: March 12, 2003 at 8:53 PM / IP Logged
No problemo..... please keep us posted on your results.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
