honda 8 way seats
G-Dubs
Member - Posts: 6
Posted: October 01, 2008 at 1:25 PM / IP Logged
I have two Honda seats that have electric 8 way positions. These seats were brought to me to be put into a '69 Camaro. I need to know if anyone has a wiring diagram for these seats. None came with them. Any help would be greatly appreciated.
gwsbigred
Platinum - Posts: 13,726
Posted: October 01, 2008 at 10:49 PM / IP Logged
Are there switches mounted to the seats? How many wires are coming out of the seats? Can you see the wires and where they actually connect to the motors?
G-Dubs
Member - Posts: 6
Posted: October 02, 2008 at 4:35 PM / IP Logged
The switches are on the side, same as side airbag. Might have come out of a 2000 Honda. Two plugs that are the side controls have 2 wires on one plug and 5 wires on the other plug. all taped together and 2 of these wires go to the motor. 12 wires then converge and go to the computer brain mounted under the seat. 4 wires then come out of there. Have a larger 18 wire plug that plugs into?? Have one 4 wired plug that I don't know where that goes. Brain box has number on it of #81228-S3M-A710-M1. Now you can see why I really need a wiring diagram, to many wires to play with. Thanks for the help.
gwsbigred
Posted: October 02, 2008 at 6:14 PM / IP Logged
On the 4 wire plug, does it look like it would have plugged into the harness that comes from the car?   How big are the wires on that plug?
What color are the wires on that plug?
G-Dubs
Member - Posts: 6
Posted: October 02, 2008 at 6:41 PM / IP Logged
Yes the 4 wire plug comes from the harness. thin wires, yellow with green stripe, green w/white stripe, black, and blue. Possibly seat belt sensors? The big plug on the drivers side has the 18 wires that come out of it, that comes out of the harness and the passenger side has 14. Need to know what all these wires control. Any wiring schematics would be great. Thanks again.
gwsbigred
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
