97 Cavalier alarm wiring
camaro5026spd
Posted: March 13, 2003 at 11:31 PM / IP Logged
I have a 97 cavalier which im installing an audiovox aps996  remote start/alarm paging system.  I have it all hooked up except for the tach wire and park/neutral safety wire.  I was wondering if anyone could tell me where these wires are and what color they might be or if i even need to hook the neutral safety  wire up at all for it to start?.  Any help would be appreciated.  Thanks
Platinum - Posts: 12,488
Posted: March 14, 2003 at 4:14 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|white               |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |*2 |either kick panel           |
|     POWER UNLOCK|white               |*2 |either kick panel           |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |harness to rear, dkp        |
|       HEADLIGHTS|dk. blue            |-  |headlight switch            |
|     DOOR TRIGGER|grn/blk & lt. blue  |-  |*3                          |
|  TRUNK/HATCH PIN|black               |-  |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |keyless module *4           |
|       TACHOMETER|PURPLE / white        |   |engine harness *1           |
|       BRAKE WIRE|white               |+  |stop light switch           |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |LF window motor in door     |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers kick panel          |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers kick panel          |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers kick panel          |
Notes:
NOTE: This vehicle has a the PASSLOCK I key based engine disabling system. Use DEI part number 555t or 555L to bypass during remote start.  *1 The engine harness is found next to the battery, below the radiator hose, just above the transaxle.   *2 Non keyless cars, locks are 5wi (type C) and they are mastered from the passenger side switch. Keyless cars, locks are positive trigger (type A).  *3 The GREEN/ black is located in the lower drivers kick panel. It catches the drivers door only. The light blue is located in the lower passenger kick panel, and catches the passenger door(s). Tap both wires and diode isolate each.  *4 The keyless module is located in the left side of the trunk behind the rear seat.
camaro5026spd
Posted: March 14, 2003 at 7:40 PM / IP Logged
Thanks for the info.  I will give it a try in the next few days.
Thanks,
Ryan
Posted: March 15, 2003 at 5:47 AM / IP Logged
No problemo.... Post any problems that you  may have.
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
