2004 trailblazer ls cabling outlet
shehabi
Posted: December 06, 2008 at 3:43 AM / IP Logged
I am trying to fix some radio equipment in my SUV and I would like to run a wire to external antenna without drilling a hole in the body.
Thank you in advance.
Platinum - Posts: 13,726
Posted: December 06, 2008 at 4:01 AM / IP Logged
What part of the vehicle are you wanting to mount the antenna? Does it have a luggage rack? Is the third brake light mounted to the roof, or to the top of the rear door?
shehabi
Posted: December 06, 2008 at 4:15 AM / IP Logged
I want to mount the antenna on the tolling hook with special modification for the base.
I am looking to run cables from inside to the antenna underneath the car.
Posted: December 06, 2008 at 4:26 AM / IP Logged
Have you looked at the firewall, for a large rubber grommet with other wires coming through it?
shehabi
Posted: December 06, 2008 at 4:35 AM / IP Logged
No, I am not sure where the firewall located is, can you direct me please?
Posted: December 06, 2008 at 7:39 AM / IP Logged
The firewall is the piece of metal that isolates the cabin of the vehicle from the engine compartment.
