2008 Mercury Mountaineer Alarm/Remote Start Wiring
tastysuds
Member - Posts: 6
Posted: February 12, 2009 at 3:00 PM / IP Logged
Hi everyone.  I'm looking for the wiring diagrams for a 2008 mercury mountaineer premier. I'm installing a Viper 5901  alarm/remote start and using a XK04 xpresskit
bob
Platinum - Posts: 13,726
Posted: February 12, 2009 at 3:14 PM / IP Logged
Remote Start Info
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.BatteryVIOLET/RED(+)IGNITION SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Ignition 1WHITE/ ORANGE(+)IGNITION SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Accessory 1VIOLET/GREEN(+)IGNITION SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Starter 1BLUE/WHITE(+)IGNITION SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Key SenseBLUE/GRAY(+)STEERING COLUMN HARNESS
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Parking LightsGRAY(-)HEADLIGHT SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Brake LightsVIOLET/WHITE(+)DRIVERS KICKPANEL
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.HornBLUE/WHITE(-)STEERING COLUMN HARNESS
Alarm Info
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.All Door TriggerYELLOW/GRAY(+)DRIVERS KICKPANEL
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Domelight SuperGREEN/ BLUE(-)DIMMER SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Alarm DisarmGREEN/ VIOLET(-)DRIVERS KICKPANEL
tastysuds
Member - Posts: 6
Posted: February 12, 2009 at 3:31 PM / IP Logged
Dam you are fast..... Thanks
bob
gotbiod
Member - Posts: 9
Posted: June 18, 2009 at 8:42 AM / IP Logged
I found your post on the 2008 Mercury Mountaineer Remote Start Wiring using the12volt search engine.  Would you be able to tell me if the wiring is the same for a Remote Start install on a 2009 Mountaineer?       Any other recommendations for remote start only (no alarm) besides the Ford PowerCode?
Thanks so much for your assist.
Ernie (gotbiod)
tommy...
Gold - Posts: 1,901
Posted: June 18, 2009 at 9:45 AM / IP Logged
All i see our 08-10...no 09...Is it the same as 2010?
M.E.C.P & First-Class
gotbiod
Member - Posts: 9
Posted: June 18, 2009 at 9:50 AM / IP Logged
Not sure.  You said 08-10.  Do you mean a range from 2008 to 2010?
ernie
tommy...
Gold - Posts: 1,901
Posted: June 18, 2009 at 10:00 AM / IP Logged
Take out the -...08,10...NO 09"
gotbiod
Member - Posts: 9
Posted: June 18, 2009 at 10:06 AM / IP Logged
Based on that, I am thinking the 09 is probably the same as the 10.  Do you have the 2010 wiring info?  can you post or PM if you have it?  I'm in PA/NJ.  Any chance you would be close by?
ernie.
tommy...
Gold - Posts: 1,901
Posted: June 18, 2009 at 7:30 PM / IP Logged
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Key SenseBLUE/GRAY(-)STEERING COLUMN HARNESS
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Parking LightsVIOLET/WHITE(+)DRIVERS DOOR SILL PLATE IN BETWEEN DRIVERS AND B PILLAR POST
YOU ARE GOING TO SEE A HARNESS THAT MAKES A SHARP RIGHT TURN UNDER DRIVERS SEAT BEFORE IT TURNS THERES GOING TO BE A VIOLET/WHITE****MAKE SURE TO TEST CONNECTION CAUSE THERE ARE ABOUT 5-6 VIOLET/WHITE WIRES.2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Low Crr. Pk Lights********DO NOT USE NEGATIVE PARKING LIGHTS OFF SWITCH2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.Brake LightsVIOLET/WHITE(+)DRIVERS KICKPANEL OR AT SWITCH
2008 Mercury Mountaineer Alarm/Remote Start Wiring -- posted image.HornBLUE/WHITE(-)STEERING COULMN HARNESS
tommy...
Gold - Posts: 1,901
Posted: June 18, 2009 at 7:32 PM / IP Logged
Only a state away...but this is still faster...
