2006 Chevy Cobalt Remote Start Wiring Diagram
oldsmobile94
Copper - Posts: 51
Posted: March 02, 2009 at 4:33 PM / IP Logged
hey i was wondering if anybody had tha alarm/starter wiring diagram for a 2006 chevy cobalt. thanks
tk
another-kelly
Silver - Posts: 618
Posted: March 02, 2009 at 11:08 PM / IP Logged
12 VOLT CONSTANT       RED / BLACK (+)       @ BCM, C3, Pin D1, See NOTE *1
STARTER       YELLOW (NOT Required for REMOTE START) See NOTE *2       @ PCM, BLUE Plug, Pin 48, 46 or 56, See NOTE *2
STARTER 2       N/A
IGNITION 1       YELLOW (+)       @ IGNITION HARNESS or BCM, C4, Pin D3, See NOTE *1
ACCESSORY /HEATER BLOWER 1       Brown       @ IGNITION HARNESS or BCM, C4, Pin C8, See NOTE *1
PARKING LIGHTS ( - )       BROWN / WHITE (-)       @ HEADLIGHT SWITCH or BCM, C2, Pin 5, See NOTE *1
PARKING LIGHTS ( + )       BROWN (+)       IN DRIVERS KICK PANEL or BCM, C2, Pin 5, See NOTE *1
POWER LOCK       WHITE (1-Wire Door Lock System) See NOTE *3       IN DRIVERS KICK PANEL or BCM, C1, Pin 7, See NOTE *1       30303_COBALT_COBALT 06 1 WIRE JBS UNITS.pdf
POWER UNLOCK       Same wire       See DIAGRAMS       30303_COBALT_COBALT 06 1 WIRE ALERT SHELBY UNITS.pdf
LOCK MOTOR WIRE       GRAY (+)       IN DRIVERS KICK PANEL or BCM, C3, Pin A4, See NOTE *1
DOOR TRIGGER       See NOTE *4       IN EACH KICK PANEL or BCM, C1, See NOTE *1       14301_COBALT_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISION       GRAY (-)       @ BCM, C3, Pin A10, See NOTE *1
TRUNK RELEASE       TAN (-)       @ TRUNK RELEASE SWITCH or BCM, C2, Pin 10, See NOTE *1
HORN       TAN (-)       @ HORN SWITCH or BCM, C2, Pin 14, See NOTE *1
TACH       ANY wire NOT PINK or PINK/BLACK       @ ANY FUEL-INJECTOR
BRAKE       LIGHT BLUE (+)       @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       DISARMS with FACTORY REWMOTE ONLY!!
ANTI-THEFT       GM'S PASSLOCK 3 TRANSPONDER ANTI-THEFT SYSTEM       @ IGNITION TUMBLER
NOTE *1 the BCM is part of the FUSE/RELAY BOX on the front PASSENGER SIDE of the CENTER CONSOLE. The BCM has the following connectors: C1-72 Pin GRAY Plug, C2-72 Pin GRAY Plug, C3-41 Pin RED Plug, and C4-68 Pin LIGHT GRAY Plug, the C4 Plug, is located on the BACK of the BCM.
NOTE *2 the PCM (Powertrain Control Module) is located on the DRIVERS SIDE FENDER, in FRONT of the UNDER HOOD FUSE BOX. The YELLOW STARTER wire is NOT required for REMOTE STARTING. THIS VEHICLE REQUIRES A PKUGM2X OR XKO6 WITH PKG7 2.0 FIRMWARE BYPASS FOR REMOTE STARTING.
NOTE *3 This vehicle uses a 1-Wire Door Locking System that will require extra parts. The LOCK requires a Straight (-) Negative and the UNLOCK requires a (-) Negative thru a 1500 Ohm Resistor. Some units will also require (2) extra Relays Part #775 for this function, to connect See DIAGRAMS.
NOTE *4 The DRIVERS DOOR is a GRAY/BLACK (-) Pin 22, The PASSENGERS DOOR is a TAN/WHITE (-) Pin 19, The DRIVERS REAR DOOR is a LIGHT BLUE/BLACK (-) Pin 1 and The PASSENGER REAR DOOR is a LIGHT GREEN/ BLACK (-) Pin 20, when connecting to an ALARM SYSTEM use all 4 wires and DIODE ISOLATE, to connect See DIAGRAM
