reverse light wire color
bowman1268
Posted: June 23, 2009 at 4:46 PM / IP Logged
I am in the middle of fixing a install by worst buy and have a question.
I need a 12+ reverse gear wire to trigger a display in the rear view mirror camera screen.Does anyone know what color this wire would be and a good place to access it?
It is a 1997 cadillac deville base
Platinum - Posts: 13,726
Posted: June 23, 2009 at 9:25 PM / IP Logged
     Reverse Lights          LIGHT GREEN          (+)          SWITCH ON TRANS.
Posted: June 24, 2009 at 4:31 PM / IP Logged
Plan B :- Test colour at rear light, follow it on loom and pick it up at which ever kick panel (probably driver's) it runs to. Just hope it doesn't do either a Peugeot or Winnie and change colour halfway through.
yimke
Copper - Posts: 417
Posted: June 27, 2009 at 10:28 AM / IP Logged
Have them do it.
You paid for a service, and the installer probably did not test to make sure it was working before it left. They have a lifetime craftsmanship on their work. Be polite to explain the situation, and you shall usually receive better/immediate service. If not, then the installer should not be in the business.
If you mess with it you void that warranty. Also if you hook it up to the wrong wire, you not only void your craftsmanship warranty, you also void your parts warranty as well if it causes damage to the unit. If you wish to do it yourself though:
1. apply e-brake
2. turn key forward to acc/ign position
3. hook your black probe on the multi-meter to a ground
4. Hook the red probe to the wire in question, move the gear shift into reverse, it should read 12v+ only when in reverse gear.
