2010 Toyota Sienna Remote Start Wiring Diagram
bluest4
Member - Posts: 37
Posted: August 06, 2009 at 4:31 PM / IP Logged
Does any one have a wiring diagram for a 2010 Toyota Sienna. I will be installing a remote start in one and it would be helpful if I had it.
richl68
Copper - Posts: 107
Posted: August 08, 2009 at 3:19 PM / IP Logged
2010 Toyota Sienna
12 VoltsWHITE/ red (30A), WHITE/ blue (7.5A)+ignition switch, white 6 pin plug, pins 5 and 1
Second 12 Voltswhite (140A)+dash fuse box, white 1 pin plug (A), pin 1
StarterBLACK / YELLOW+ignition switch, white 6 pin plug, pin 4
Second StarterN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Ignitionblack+ignition switch, white 6 pin plug, pin 6
Second IgnitionBLACK / YELLOW+ignition switch, white 6 pin plug, pin 2
Third IgnitionN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Accessorypink+ignition switch, white 6 pin plug, pin 3
Second AccessoryN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Third AccessoryN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Keysenseblue/black-ignition key switch, white 4 pin plug, pin 2
Data Busyellow (RX), yellow/red (TX)dataTransponder Key Amplifier, black 7 pin plug, pins 4 and 5
The Transponder Key Amplifier is around the ignition key switch. The immobilizer light wire is black (+) at the instrument cluster, white 40 pin plug, pin 4. The IMO - IMI wires are BROWN / white - BROWN / red at the ECM, white 35 pin plug (E5, second plug from top), pins 15 and 16. The ECM (Engine Control Module) is under the passenger dash, behind the glove box.
richl68
Copper - Posts: 107
Posted: August 08, 2009 at 3:21 PM / IP Logged
Can Bus Highblackdatadata link connector, white 16 pin plug, pin 6
Can Bus Lowwhitedatadata link connector, white 16 pin plug, pin 14
Can Bus SwN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Power LockRED / yellow-driver kick, white 12 pin plug, pin 7
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm arm wire.
Power Unlockgreen-driver kick, white 12 pin plug, pin 9
This wire is only needed if the door locks do not function with the aftermarket system while the vehicle is running. All other times just use the factory alarm disarm wire.
Lock Motorblue/red5 wiredriver kick, white 12 pin plug, pin 11
Driver Unlock Motorred to WHITE/ red5 wiredriver kick, white 18 pin plug, pin 2
Passenger Unlock Motorblue/black5 wiredash fuse box, white 12 pin plug (J), pin 2
Parking Lights (-)GREEN/ black-headlight switch, white 17 pin plug, pin 14
Parking Lights (+)do not use, factory relay rests at ground2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
HazardsBLACK/ orange-hazard switch, black 6 pin plug, pin 4
Turn Signal (Left)GREEN/ black+dash fuse box, white 30 pin plug (C), pin 14
Turn Signal (Right)GREEN/ YELLOW+dash fuse box, white 30 pin plug (C), pin 17
HeadlightRED / green-headlight switch, white 17 pin plug, pin 13
AutoLightspurple (interrupt to turn off autolights)-headlight switch, white 17 pin plug, pin 12
Reverse LightRED / black+dash junction block, white 32 pin plug (J12), pin 17
richl68
Copper - Posts: 107
Posted: August 08, 2009 at 3:22 PM / IP Logged
Left Front Door TriggerRED / yellow-dash junction block, white 32 pin plug (J12), pin 22
Right Front Door TriggerRED / yellow-harness above and behind dash fuse box
Left Rear Door Triggergray-dash fuse box, white 25 pin plug (P), pin 19
Right Rear Door TriggerRED / white-harness above and behind dash fuse box
Dome Supervisionblue (in), RED / green (out)-interior light switch, white 10 pin plug, pins 5 and 10
Trunk/Hatch PinGREEN / WHITE-dash junction block, white 32 pin plug (J14), pin 26
Rear Glass PinN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Hood PinRED / white-dash junction block, white 34 pin plug (J3), pin 13
Trunk/Hatch ReleaseGREEN/ black-dash junction block, white 32 pin plug (J14), pin 7
Meter this wire while opening the liftgate from the handle on the rear of the vehicle. On vehicles with power liftgate, the open/close wire is yellow/red (-), below the dash junction block, white 22 pin plug, pin 10.
Trunk Release Motorblue/black5 wiredash junction block, white 16 pin plug (J10), pin 14
Fuel Door ReleaseN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Power Sliding Door (Left)YELLOW /GREEN-below dash junction block, white 22 pin plug, pin 11
Power Sliding Door (Right)purple-below dash junction block, white 22 pin plg, pin 9
Factory Alarm Armlt. green-driver kick, white 18 pin plug, pin 5
Meter this wire while turning the key in the driver door key cylinder. This wire will also lock the doors.
richl68
Copper - Posts: 107
Factory Alarm Disarmblue (double pulse)-driver kick, white 18 pin plug, pin 7
Meter this wire while turning the key in the driver door key cylinder. This wire will also unlock the doors.
Disarm No Unlockuse keysense2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Trunk Alarm ShuntN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
TachometerBLACK/ orangeacECM, white 35 pin plug (E5, second plug from top), pin 1
The ECM (Engine Control Module) is under the passenger dash, behind the glove box. Also found at the instrument cluster, white 40 pin plug, pin 37.
Wait to StartN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Neutral SafetyN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Clutch PedalN/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Fuel PumpBLACK/ red+driver kick, harness to rear
Rear DefrosterYELLOW /GREEN- latcheddash junction block, white 34 pin plug (J3), pin 11
Mirror Defrostersame as rear defroster2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Left Front Heated Seatorange+ latcheddriver seat heater switch, black 6 pin plug, pin 4
Right Front Heated Seatblue/black+ latchedpassenger seat heater switch, white 6 pin plug, pin 4
Speed SensePURPLE / whiteacradio, white 20 pin plug, pin 3
On 10 speaker systems, it is in the white 16 pin plug, pin 4. On vehicles with navigation, it is in the gray 5 pin plug, pin 3.
Brake WireGREEN / WHITE+dash fuse box, white 25 pin plug (P), pin 3
Parking BrakeRED / white-dash fuse box, white 36 pin plug (K), pin 10
Horn TriggerGREEN/ black-dash fuse box, white 30 pin plug (C), pin 25
richl68
Copper - Posts: 107
Posted: August 08, 2009 at 3:24 PM / IP Logged
Wipersblue/black (L), blue/orange (H)+wiper switch, black 18 pin plug, pins 7 and 8
Left Front Window (Up/Down)red - greenApower window master switch, white 18 pin plug, pins 4 and 9
Right Front Window (Up/Down)RED / blue - BLACK/ white to GREEN / WHITEAdriver kick, white 18 pin plug, pins 11 and 10
Left Rear Window (Up/Down)pink to RED / yellow - blue/red to GREEN/ YELLOWAdriver kick, white 18 pin plug, pins 18 and 17
Right Rear Window (Up/Down)RED / black - black to GREEN/ blackAdriver kick, white 18 pin plug, pins 9 and 8
Sun Roof (Open/Close)RED / white - RED / blue (functions with ign on only)-moon roof switch, white 8 pin plug, pins 2 and 6
Sun Roof (Limit/Close)N/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Memory Seat 1pink/blue-seat memory switch, white 4 pin plug, pin 4
Memory Seat 2lt. GREEN/ black-seat memory switch, white 4 pin plug, pin 3
Memory Seat 3N/A2010 Toyota Sienna Remote Start Wiring Diagram -- posted image.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
