1996 lexus es300 vss info
sandrelli
Member - Posts: 9
Posted: December 27, 2009 at 2:16 PM / IP Logged
Looking for VSS info on a 1996 Lexus ES300. I am installing a taxi meter into this particular car. Any help would be greatly appreciated. Thanks in advance!
mustyk@att.net
Copper - Posts: 132
Posted: December 29, 2009 at 5:14 PM / IP Logged
WE have a wiring diagram of the instrument cluster with two VSS signal wires. One is an input from the VSS sensor and the other is an output from the cluster to the ECU, cruise module and other units. Try either one, but the input signal is a raw A/C signal from the sensor and the output is a conditioned square wave.
INPUT: Green wire--Connector "B" pin 13
OUTPUT: Violet / YELLOW--Conn "B"  pin14
Hope this helps!
thetopinstaller
Friday, January 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
