aussie spec 2006 2006 hyundai accent lc2
boosted_hyundai
Posted: January 02, 2010 at 5:53 PM / IP Logged
Hello all, first post on here, hope you can all help me out...
In Australia I'm having major dramas with both Hyundai Australia and Local Auto Electrians. No one is Allowed to give or show me a wiring diagram for the electric window setup for a 2 door 2003-2006 Accent. I hope someone can here can help me out. I have all the factory components to be transplanted into another car however the dash was to crumpled to get the wiring out from under the dash. PLEASE PLEASE PLEASE... someone must be able to track down a wiring diagram for me.
Cheers Ryan
Platinum - Posts: 13,725
Posted: January 02, 2010 at 6:59 PM / IP Logged
If you can not find any info for the vehicle, it is very easy to use 2 relays and a single switch to get the windows to work.
aussie spec 2006 2006 hyundai accent lc2 -- posted image.
Posted: January 03, 2010 at 2:44 AM / IP Logged
Be careful here, they might use the Mits set-up with the processors attached to the motors. The wiring set up is a right can of worms, data or ground signal at the slave switches etc.
boosted_hyundai
Posted: January 17, 2010 at 4:42 AM / IP Logged
hey it is supposed to be 2003-2006 Hyundai Accent...
Now i am trying to use all the factory switches seeing as i have the original door cards and everything except for the wiring...Im trying to go to the wreckers to see if i can track one down to trace each wire but yer, my chances are very slim.
Cheers Ryan
