08 accord viper 5301 wiring
rich7557
Posted: January 15, 2010 at 6:53 PM / IP Logged
Looking for detailed Viper 5301 starter wiring specs and guidance for an 08 Honda Accord four sedan automatic with canmax400 kit.
Tried the DEI site for but no luck on detailed honda wiring instructions. Dealer only site.
I also decided to use canmax400 d2d connection to reduce wiring required in this installation, i had canmax flashed with firmware level Honda5.
I pulled down an 08 accord wiring diagram from Bulldog site and still a bit confused with viper H3 wiring hookup.
After reading install manual several times, here is my first attempt at planning out just the heavy gauge remote starter H3 harness hookups to honda.
Honda 12 VOLT CONSTANT   WHITE (+)  to Viper  H1/2 12V constant input in harness H1
 Honda STARTER 1                  YELLOW (+) to Viper  H3/4  Starter output
 Honda STARTER 2                                                    N/A
 Honda IGNITION 1                      BLUE (+)  to Viper  H3/1 ignition 1 input/ouput
 Honda IGNITION 2                                                     N/A
 Honda IGNITION 3                                                     N/A
 Honda ACCESSORY /HEATER BLOWER 1  RED (+)  to Viper  H3/3 Accessory output
 Honda ACCESSORY /HEATER BLOWER 2  ORANGE (+)  to Viper  H3/ which wire should use here in H3 harness?.
I know your not required to connect all the wires as most third party starters are design to work with many different model cars.
Now I am left with 5 out of 8 wires in H3 harness.
H3/2 (+) fused (30a) ignition 2/flex relay input 87 (Not needed?)
H3/5 (+) fused (30a)ignition 1 input   (does this wire tie back to honda iginition 1 wire?)
H3/6 (+)ignition 2 / flex relay output 30  (Not needed?)
H3/7  flex relay input 87a key side if required (Not needed?)
h3/8 (+) fused (30a) accessory/starter input (does this wire tie back to honda starter 1 wire?)
Any help instructions you can provide here will go a long way.
Thanks in advance Rich
Posted: January 16, 2010 at 4:19 AM / IP Logged
Contact Tedmund, he's the expert on these.
rich7557
Posted: January 16, 2010 at 7:57 AM / IP Logged
I'll drop Tedmund an email shortly with my questions.
For anyone else looking for 08 Honda wire location and colors, I found Tedmund's following download doc termendously useful.
https://www.the12volt.com/installbay/file.asp?ID=808
Thank you all!
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
