2011 Kia Sorento Alarm/Remote Start Wiring
metz35
Copper - Posts: 458
Posted: February 15, 2010 at 10:03 AM / IP Logged
any one got anything on this vechicle, its new revamped for 2011?
tedmond
Gold - Posts: 4,610
Posted: February 15, 2010 at 4:42 PM / IP Logged
2011 Kia Sorento
 Remote Start
  Item  Wire Color  Polarity  Wire Location
 12 Volts  red (40A)  +  ignition switch, black 6 pin plug, pin 1
  On vehicles with Smart Key, this wire is in the driver kick, white 15 pin plug, pin 11.
 Second 12 Volts  pink (30A)  +  ignition switch, black 6 pin plug, pin 5
  On vehicles with Smart Key, this wire is in the driver kick, white 15 pin plug, pin 12.
 Starter  green  +  ignition switch, black 6 pin plug, pin 3
  On vehicles with Smart Key, this wire is red (+) at the dash fuse box, white 8 pin plug (C), pin 4.
 Second Starter  BLACK/ orange and pink (push-button start)  +  start/stop button switch, black 10 pin plug, pins 1 and 7
 Ignition  orange  +  ignition switch, black 6 pin plug, pin 4
  On vehicles with Smart Key, this wire is green (+) at the dash fuse box, white 8 pin plug (C), pin 3.
 Second Ignition  N/A
 Third Ignition  N/A
 Accessory  blue  +  ignition switch, black 6 pin plug, pin 2
  On vehicles with Smart Key, this wire is at the dash fuse box, white 8 pin plug (C), pin 2.
 Second Accessory  yellow  +  ignition switch, black 6 pin plug, pin 6
  On vehicles with Smart Key, this wire is at the dash fuse box, white 8 pin plug (C), pin 1.
 Third Accessory  N/A
 Keysense  yellow  -  ignition key switch, white 6 pin plug, pin 4
  On vehicles with Smart Key, the key fob holder sense wire is red at the dash fuse box, rear, white 16 pin plug (MM), pin 8.
 Data Bus  blue/orange or blue to red (immobilizer data)  data  passenger kick, green 18 pin plug, pin 18
  The immobilizer light wire is BROWN / orange or brown (-) in the passenger kick, green 18 pin plug, pin 17 (without Smart Key), or instrument cluster, black 12 pin plug, pin 5 (with Smart Key).
 Can Bus High  white (C-CAN)  data  data link connector, black 16 pin plug, pin 3
  The B-CAN high wire is blue at the dash fuse box, rear, white 16 pin plug (MM), pin 5.
 Can Bus Low  red (C-CAN)  data  data link connector, black 16 pin plug, pin 11
  The B-CAN low wire is red at the dash fuse box, rear, white 16 pin plug (MM), pin 6.
 Can Bus Sw  N/A
 Power Lock  blue/black  -  dash fuse box, white 26 pin plug (FK), pin 4
 Power Unlock  gray/black  -  dash fuse box, white 26 pin plug (FK), pin 24
  To unlock the driver door only, use yellow/black (-) at the dash fuse box, rear, white 16 pin plug (MM), pin 2.
 Lock Motor  orange  5 wire  dash fuse box, white 39 pin plug (A), pin 16
 Driver Unlock Motor  green  5 wire  driver kick, door harness
 Parking Lights (-)  blue  -  headlight switch, white 13 pin plug, pin 2
 Parking Lights (+)  green (L), yellow (R)  +  dash fuse box, white 39 pin plug (A), pins 11 and 7
 Hazards  yellow  -  dash fuse box, rear, white 16 pin plug (MM), pin 10
 Turn Signal (Left)  white (F); white (R)  +  dash fuse box, red 20 pin plug (F), pin 10; wht 39 pin plug (A), pin 14
 Turn Signal (Right)  yellow/black (F); pink (R)  +  dash fuse box, red 20 pin plug (F), pin 20; wht 39 pin plug (A), pin 13
 Headlight  blue  -  headlight switch, white 13 pin plug, pin 4
 AutoLights  green (interrupt to turn off autolights)  -  headlight switch, white 13 pin plug, pin 3
 Reverse Light  red  +  dash fuse box, white 39 pin plug (A), pin 15
 Left Front Door Trigger  GREEN/ orange  -  dash fuse box, white 26 pin plug (FK), pin 10
 Right Front Door Trigger  pink/black  -  dash fuse box, white 26 pin plug (FK), pin 18
 Left Rear Door Trigger  white  -  dash fuse box, white 26 pin plug (FK), pin 7
 Right Rear Door Trigger  gray/black  -  dash fuse box, white 26 pin plug (FK), pin 5
 Dome Supervision  brown  -  left front pillar, white 22 pin plug, pin 1
 Trunk/Hatch Pin  yellow/black  -  dash fuse box, white 26 pin plug (FK), pin 19
 Rear Glass Pin  N/A
 Hood Pin  RED / black  -  dash fuse box, red 20 pin plug (F), pin 16
 Trunk/Hatch Release  yellow/black  -  dash fuse box, white 26 pin plug (FK), pin 11
  Meter this wire while opening the liftgate from the handle on the rear of the vehicle.
 Trunk Release Motor  blue  +  dash fuse box, white 39 pin plug (A), pin 26
 Fuel Door Release  blue/orange  +  driver kick, door harness
 Power Sliding Door (Left)  N/A
 Power Sliding Door (Right)  N/A
 Factory Alarm Arm  BROWN / orange and gray  - and open  dash fuse box, white 26 pin plug (FK), pins 21 and 26
  Meter these wires while turning the key in the driver door key cylinder. See Tech Doc 1300 for wiring information.
 Factory Alarm Disarm  pink and gray (double pulse)  both -  dash fuse box, white 26 pin plug (FK), pins 9 and 26
 Disarm No Unlock  see factory alarm disarm
 Trunk Alarm Shunt  N/A
 Tachometer  NOT orange or pink/black  ac  any fuel injector
 Wait to Start  N/A
 Neutral Safety  N/A
 Clutch Pedal  black (in), WHITE/ orange (out)  - N.O.  clutch switch, white 2 pin plug, pins 1 and 2
 Fuel Pump  blue  +  dash fuse box, white 39 pin plug (A), pin 30
 Rear Defroster  gray  - latched  dash fuse box, red 20 pin plug (F), pin 17
 Mirror Defroster  same as rear defroster
 Left Front Heated Seat  yellow  + latched  driver kick, blue 22 pin plug, pin 15
 Right Front Heated Seat  yellow  + latched  passenger kick, yellow 22 pin plug, pin 19
 Speed Sense  brown  ac  data link conn, blk 16 pin plug, pin 6 or radio, gry 8 pin plug, pin 1
 Brake Wire  yellow (2.4L), GREEN/ black (3.5L)  +  brake switch, white 4 pin plug, pin 1
 Parking Brake  gray  -  dash fuse box, white 26 pin plug (FK), pin 6
 Horn Trigger  gray/black to gray  -  driver kick, white 15 pin plug, pin 6
 Wipers  green (L), pink (H)  +  wiper switch, white 14 pin plug, pins 3 and 9
 Memory Seat 1  N/A
 Memory Seat 2  N/A
 Memory Seat 3  N/A
Ted
Compustar Expert
metz35
Copper - Posts: 458
Posted: February 16, 2010 at 6:55 PM / IP Logged
thanks! much appreciated
tedmond
Gold - Posts: 4,610
Posted: February 17, 2010 at 6:48 AM / IP Logged
no prob.
Ted
Compustar Expert
jcharville
Posted: January 24, 2011 at 7:26 AM / IP Logged
Does anyone know if I need to install the bypass key immobilizer on the sorento?
Kia Sorento
Platinum - Posts: 7,827
Posted: January 24, 2011 at 7:42 AM / IP Logged
Here is some info from iDatalink :  http://12voltdata.com/viewtopic.php?f=282&t=4654
jcharville
Posted: January 24, 2011 at 8:33 AM / IP Logged
Kia Sorento
chev104275
Gold - Posts: 1,436
Posted: January 24, 2011 at 6:17 PM / IP Logged
I've done a few of these they didn't have a transponder
Thursday, January 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
