2008 gmc sierra 1500 2wd
fleetfixer
Posted: May 28, 2010 at 9:54 PM / IP Logged
Need cruise control wiring diagram.
Do it right the first time. Every time!
Moderator - Posts: 12,488
Posted: May 29, 2010 at 7:44 AM / IP Logged
What system? Rostra, Audiovox or OEM ?
fleetfixer
Posted: May 29, 2010 at 11:11 PM / IP Logged
I need oem wiring. Installing on-board computer for fleet management. Need to monitor usage.
Platinum - Posts: 13,725
Posted: May 30, 2010 at 8:50 AM / IP Logged
Do you need to monitor usage of the cruise control, or monitor mileage put on vehicle?   If the latter, would a Vehicle Speed Sense wire work for what you need?  We can probably help with that.
fleetfixer
Posted: May 30, 2010 at 12:56 PM / IP Logged
Both. I have found a vss (the one the factory radio uses) the customer wants to monitor cruise control activations. Thanks for the help.
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
