2003 mitsubishi diamante vr x
theprox
Posted: October 27, 2010 at 9:09 AM / IP Logged
I have a 2003 Mitsubishi Diamante VR-X that was broken into and had the wires cut. I am trying to find a wiring diagram / chart to show what the wires are for the radio (it is a amped system, so there are only 5 or 6 wires in the dash) and the environmental controls (for the ac/heater unit). Any help would be appreciated.
91stt
Silver - Posts: 564
Posted: October 29, 2010 at 3:24 PM / IP Logged
diagrams for climate control:
environmental control diagrams
diagrams for audio system:
radio diagrams
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
theprox
Posted: October 29, 2010 at 5:07 PM / IP Logged
Thank you soooooooo much. This is exactly what I needed. I haven't been able to find this anywhere else. You are a life saver!
theprox
Posted: November 19, 2010 at 6:03 PM / IP Logged
For the environmental controls, do you know what the voltage should be that is going to the air mix motor and the mode motor?
Thanks in advance!
91stt
Silver - Posts: 564
Posted: November 22, 2010 at 10:03 AM / IP Logged
pin #21 (mode selector motor) in face position = 10V
"    "   "     "       "     in defrost position = about 0.5V
pin #22 (air mix damper motor) in max hot position = about 0.5V
"    "   "   "    "     "     in max cool position = 10V
pin #24 (air mix damper motor) in max cool position = 10V
"    "   "   "    "     "      in max hot position = about 0.5V
pin #25 (mode selector motor) in defrost position = 10V
"   "    "      "       "    in face position = about 0.5V
