04 mazda 3 remote start wiring
hondaclx2k1
Member - Posts: 11
Posted: December 01, 2010 at 8:03 AM / IP Logged
looking for info to do a remote start on a 2004 mazda 3 thanks
tonanzith
Gold - Posts: 603
Posted: December 19, 2010 at 1:15 AM / IP Logged
2004 Mazda Mazda3      DirectWire 2.0 Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red (30A)     +     ignition harness
Second 12 Volts     BLACK/ red (30A)     +     ignition harness
Starter     gray/black     +     ignition harness
Second Starter     N/A
Ignition     GREEN/ YELLOW     +     ignition harness
Second Ignition     N/A
Third Ignition     N/A
Accessory     pink / YELLOW     +     ignition harness
Second Accessory     yellow     +     ignition harness
Third Accessory     N/A
Keysense     RED / black     +     ignition harness
Data Bus     gray/orange (TX), WHITE/ green (RX)     data     PATS Transceiver, 4 pin plug, pins B and A
     The PATS (Passive Anti-Theft System) Transceiver is around the ignition switch. The PATS ignition wire is GREEN/ red in pin D, and ground wire is BLACK / YELLOW in pin C.
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock     GREEN/ red     -1000 ohms     driver kick, door harness
     Lock is negative trigger thru an 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock     same as power lock wire     -
Lock Motor     yellow/black     5 wire     driver kick, door harness
Driver Unlock Motor     WHITE/ black     5 wire     driver kick, door harness
Passenger Unlock Motor     WHITE/ black     5 wire     driver rear door harness
Parking Lights (-)     BLACK/ white     -     headlight switch
Parking Lights (+)     ORANGE / white (L), orange (R)     +     passenger kick, harness to rear
Hazards     BLACK/ orange     -     hazard switch
Turn Signal (Left)     blue     +     passenger kick, harness to rear
Turn Signal (Right)     blue/red     +     passenger kick, harness to rear
Headlight     BLACK/ green     -     headlight switch
AutoLights
Reverse Light     GREEN/ orange or GREEN/ black     +     passenger kick, harness to rear
Left Front Door Trigger     BLACK / YELLOW     - N.C.     passenger kick, harness to rear
     These wires are also found at the Passenger Junction Box behind the glove box.
Right Front Door Trigger     BLACK/ blue     - N.C.     passenger kick, harness to rear
Left Rear Door Trigger     BLACK/ orange     - N.C.     passenger kick, harness to rear
Right Rear Door Trigger     BLACK/ green     - N.C.     passenger kick, harness to rear
Dome Supervision     BLACK/ blue to BLACK/ red     -     passenger kick, harness to rear
Trunk/Hatch Pin     BLACK/ red or BLACK/ blue     -     passenger kick or light in trunk
Rear Glass Pin
Hood Pin     BLACK / YELLOW     -     hood pin switch
Trunk/Hatch Release     N/A
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     BLACK/ blue     -     driver kick, door harness
     Meter this wire while turning the key in the driver door key cylinder. This wire may also lock the doors.
Factory Alarm Disarm     BLACK/ white     -     driver kick, door harness
     Meter this wire while turning the key in the driver door key cylinder. This wire may also unlock the doors.
Disarm No Unlock
Trunk Alarm Shunt
Tachometer     NOT GREEN/ stripe     ac     any ignition coil or fuel injector
Wait to Start     N/A
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense     wheel speed sensor
Brake Wire     RED / white     +     brake pedal switch
Parking Brake     BLACK/ lt. green     -     parking brake switch
Horn Trigger     black     -     horn switch
Wipers     BLACK/ green (L), BLACK/ red (H)     -     windshield wiper switch
Left Front Window (Up/Down)     yellow/black - WHITE/ green     A     driver window switch in door
Right Front Window (Up/Down)     yellow/purple - WHITE/ purple     A     driver kick, door harness
Left Rear Window (Up/Down)     blue/white - purple     A     driver kick, door harness
Right Rear Window (Up/Down)     GREEN/ YELLOW - GREEN / WHITE     A     driver kick, door harness
Sun Roof (Open/Close)     motor part of module
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     red to ORANGE / black     +     radio harness
Radio Ground     BLACK/ green     -     radio harness
Radio Ignition     yellow     +     radio harness
Radio Illumination     ORANGE / black     +     radio harness
Factory Amp Turn-on     N/A
Power Antenna     N/A
Left Front Speaker (+/-)     WHITE/ black - gray/black     +,-     radio harness
Right Front Speaker (+/-)     WHITE/ red - gray/red     +,-     radio harness
Left Rear Speaker (+/-)     WHITE/ purple - gray/white     +,-     radio harness
Right Rear Speaker (+/-)     white - gray     +,-     radio harness
Center Channel (+/-)
Subwoofer (+/-)
Aux. Audio Input Left (+/-)
Aux. Audio Input Right (+/-)
RSE Video (+/-)
RSE Audio Left (+/-)
RSE Audio Right (+/-)
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
Item     Size     Depth     Location
Headunit     irregular          center of dash
Left Front Speaker     6 x 8     3.5     left front door
Left Front Tweeter
Right Front Speaker     6 x 8     3.5     right front door
Right Front Tweeter
Left Rear Speaker     6 x 8     3.5     left rear door
Left Rear Tweeter
Right Rear Speaker     6 x 8     3.5     right rear door
Right Rear Tweeter
Center Channel
Subwoofer
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Interface Modules
SKU     Module Description     Upgradeable     Keys Required for Programming     Keys Required for Operation
Gary Sather
Sunday, January 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
