2010 toyota 4runner
Welcome Guest :)
seal2127
Member -
Posted: December 29, 2010 at 4:26 PM / IP Logged
I need the remote start alarm wiring for a 2010 Toyota 4Runner thank you
are u serious
dragonpntr
Member -
Posted: January 22, 2011 at 12:16 AM / IP Logged
2010 Toyota 4Runner
Constant 12 volts |
BLACK (140A) |
DASH FUSE BOX WHITE 1 PIN CONN |
Ignition 12 volts |
BLACK |
IGNITION SWITCH |
Starter |
RED |
IGNITION SWITCH |
Dome Light |
GREEN (-) |
REAR OF DASH FUSE BOX WHITE 40 PIN CONN, PIN 18 |
Driver's Front Door Pin |
RED (-) |
DASH FUSE BOX WHITE 36 PIN CONN, PIN 27 |
Pass Front Door Pin |
BLACK (-) |
REAR OF DASH FUSE BOX WHITE 40 PIN CONN, PIN 15 |
Driver's Rear Door Pin |
VIOLET (-) |
BECU WHITE 30 PIN CONN, PIN 3 |
Pass Rear Door Pin |
RED (-) |
BECU WHITE 30 PIN CONN, PIN 6 |
Trunk Pin |
PINK (-) |
BACK DOOR ECU WHITE 26 PIN CONN, PIN 10 |
Parking Lamp |
GREEN (+) |
DASH FUSE BOX WHITE 36 PIN CONN, PIN 16 |
Lock |
LT GREEN (-) |
BECU WHITE 30 PIN CONN, PIN 11 * #201 |
Unlock |
GRAY (- DOUBLE PULSE) |
BECU WHITE 30 PIN CONN, PIN 24 |
IGNITION DATABUS |
LT GREEN (RX) VIOLET (TX) |
IGNITION SWITCH |
CAN BUS |
VIOLET (CAN HIGH) WHITE (CAN LOW) |
OBDII PINS 6 & 14 |
* Body ECU is under drivers dash attached to fuse
Tach Signal |
PINK |
OBDII PIN 9 |
< size=3 face=Calibri>< size=3 face=Calibri>
Ignition #2 |
VIOLET |
IGNITION SWITCH |
Ignition #3 |
NA |
Accessory |
RED |
IGNITION SWITCH |
Accessory #2 |
NA |
Accessory #3 |
NA |
Starter #2 |
BLACK |
IGNITION SWITCH |
Neutral Safety |
NA |
Brake Light |
VIOLET\GREEN (+) |
BRAKE SWITCH |
Parking Brake |
LT GREEN (-) |
DASH FUSE BOX WHITE 40 PIN CONN, PIN 17 |
Clutch Pedal |
NA |
Reverse Light |
RED (+) |
DASH FUSE BOX WHITE 36 PIN CONN, PIN 4 |
Rear Defrost |
PINK (- LATCHED) |
DRIVER KICK WHITE 64 PIN CONN, PIN 61 |
Window Up |
| ON DEMAND PULSE ON ARM WIRE WILL ROLL WINDOWS UP |
| Window Down |
ON DEMAND PULSE ON DISARM WIRE WILL ROLL WINDOWS DOWN |
| Keysense |
BLACK (-) (W\O SMARTKEY) |
BECU WHITE 30 PIN CONN, PIN 17 |
| Trunk Release |
RED (5 WIRE) |
DASH FUSE BOX WHITE 36 PIN CONN, PIN 9 |
| OEM Horn |
GRAY\BLUE (-) |
DASH FUSE BOX WHITE 40 PIN CONN, PIN 29 |
| Headlights |
PINK (LOW) PINK (HIGH) |
DASH FUSE BOX WHITE 40 PIN CONN, PINS 40 & 24 |
| OEM Alarm Arm |
SAME AS LOCK WIRE |
| OEM Alarm Disarm |
SAME AS UNLOCK WIRE |
| Vehicle Speed Sense |
GREEN |
DRIVER KICK WHITE 48 PIN CONN, PIN 11 |
Keysense |
Trunk Release |
RED (5 WIRE) |
OEM Horn |
GRAY\BLUE (-) |
OEM Alarm Arm |
SAME AS LOCK WIRE |
OEM Alarm Disarm |
Thursday, February 19, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
