2010 Lexus RX350 Amplifier Wiring Diagram
krik
Posted: April 10, 2011 at 11:05 PM / IP Logged
In need of wiring diagram for 2010 Lexus RX350 factory amplifier for the basic 9 speaker sound system without NAV. Specifically, the color codes for RR and LR speakers, +/-. If you have it, I'd greatly appreciate it.
Thanks.
Mike M2
Platinum - Posts: 2,652
Posted: April 13, 2011 at 4:35 PM / IP Logged
Radio 12V lt. green + radio, white 20 pin plug, pin 1 or white 28 pin plug, pin 14
Radio Ground brown - radio, white 20 pin plug, pin 20 or white 28 pin plug, pin 15
Radio Ignition yellow or gray + radio, white 20 pin plug, pin 11 or white 16 pin plug, pin 16
Radio Illumination green (parking lights), blue (dimmer) +,- radio, wht 20 pin plug, pins 2, 12 or wht 28 pin plug, pins 3, 17
Factory Amp Turn-on N/A
Power Antenna N/A
Left Front Speaker (+/-) white - red (mid and high); red - white (low) +,- amplifier, wh 10 pin plg, pins 1 and 5; wh 12 pin plg, pins 3 and 8
The amplifier is in the cargo compartment floor, behind the passenger side rear seat. On vehicles with navigation, the tweeter wires are in pins 3 and 9.
Right Front Speaker (+/-) purple - pink (mid and high); black - yellow (low) +,- amplifier, wh 10 pin plg, pins 2 and 6; wh 12 pin plg, pins 10and9
The amplifier is in the cargo compartment floor, behind the passenger side rear seat. On vehicles with navigation, the tweeter wires are in pins 4 and 10.
Left Rear Speaker (+/-) brown - green +,- amplifier, white 12 pin plug, pins 4 and 11
The amplifier is in the cargo compartment floor, behind the passenger side rear seat. The surround speaker wires are pink - purple at the amplifier, white 12 pin plug, pins 1 and 6.
Right Rear Speaker (+/-) yellow - blue +,- amplifier, white 12 pin plug, pins 5 and 12
The amplifier is in the cargo compartment floor, behind the passenger side rear seat. The surround speaker wires are lt. green - blue at the amplifier, white 12 pin plug, pins 2 and 7.
Center Channel (+/-) green - gray +,- amplifier, white 10 pin plug, pins 8 and 7
Subwoofer (+/-) black - red (1), yellow - green (2) +,- amplifier, white 10 pin plug, pins 1 and 5 (1), 2 and 6 (2)
Aux. Audio Input Left (+/-) black - red (common) +,- radio, white 20 pin plug, pins 17 and 16
On vehicles with navigation, they are at the radio, white 28 pin plug, pins 20 and 21.
Aux. Audio Input Right (+/-) white - red (common) +,- radio, white 20 pin plug, pins 15 and 16
On vehicles with navigation, they are at the radio, white 28 pin plug, pins 19 and 21.
RSE Video (+/-) brown - yellow (with navigation only) +,- navigation receiver, wht 22 pin plg, pins 4 and 14
The navigation receiver is below the radio.
RSE Audio Left (+/-) red - green (USB audio) +,- radio, black 12 pin plug, pins 4 and 5
On vehicles with navigation, they are red - black (common) at the navigation receiver, black 8 pin plug, pins 4 and 7. The navigation receiver is below the radio.
RSE Audio Right (+/-) black - white (USB audio) +,- radio, black 12 pin plug, pins 2 and 3
On vehicles with navigation, they are white - black (common) at the navigation receiver, black 8 pin plug, pins 3 and 7. The navigation receiver is below the radio.
Mike M2
Tech Manager
CS Dealer Services
krik
Posted: April 13, 2011 at 10:14 PM / IP Logged
Thanks Mike! I really appreciate it.
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
