alarm wiring for vauxhall/opel astra mk3
josh_mk3
Posted: May 20, 2011 at 5:14 PM / IP Logged
hello,
I want to fit an alarm me my car but i cant find a wiring diagram anywhere :s
Car is a 1996 vauxhall/opel/GM Astra mk3
i listed all 3 makes because i dont know what they call vauxhall in america :)
Posted: May 21, 2011 at 12:31 AM / IP Logged
It was sold in the US as a Pontiac Le Mans and built by Daewoo.
The wiring is different.
Can you operate ALL of the locks from both front doors?
If only the driver's you will need an actuator in the driver's door, don't panic it directly replaces the Keikart switch. Otherwise:
Lock BROWN / red.
Unlock BROWN / white, both NEG pulse.
Indicators BLACK/ green, BLACK/ white passenger floor loom.
Door triggers, plain grey entry loom from doors (either front)left hand side easier to access.
Trunk trigger, BROWN / white at the trunk (hatch)light.
121V+ Constant thick red ign. switch loom.
Ignition black at above.
Starter BLACK/ red at above.
Hood (bonnet) pin switch required.
josh_mk3
Posted: June 05, 2011 at 11:30 AM / IP Logged
yea i can operate all the locks from both doors,
so the only part of the loom i need access to is in the passenger foot-well and the ignition barrel?
Thanks for the help :)
Posted: June 05, 2011 at 12:21 PM / IP Logged
Yes.
