2004 suzuki grand vitara rhd
t&t tech
Platinum - Posts: 2,622
Posted: May 20, 2011 at 8:01 PM / IP Logged
Battery - WHITE/ green
Ignition - Blue/black
Ignition 2 - Yellow/black
Accessory - Blue
Starter - BLACK / YELLOW (located under driver dashboard panel)
Door Lock- Pink/black
Door Unlock - Pink/green (Both are negative trigger, located to the right of steerig column, in the bottom grey plug)
Parking Lights - RED / yellow (+)
Trunk trigger and door trigger are found in a common wire that is BLACK/ red. Parking lights and the door and trunk trigger are located in the driver kick panel.
Brake wire - GREEN / WHITE DKP
Note in the DKP there are seperated wires for the trunk and door trigger, if required, however the one listed sees all parts of the SUV except the hood.
No transponder Present.
Posted: May 21, 2011 at 12:22 AM / IP Logged
Grey import, clever X 4 and why the hell are you still a standard member rather than GOLD?
