2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring
kendukes
Posted: July 23, 2011 at 1:05 PM / IP Logged
I was wandering if someone could help me out with a wiring diagram for a 20011 Mitsubishi Outlander Sport so I can install a car alarm and remote start?
Any help would be appreciated.
Thanks.
Platinum - Posts: 13,725
Posted: July 23, 2011 at 7:41 PM / IP Logged
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Battery YELLOW (+) IGNITION SWITCH HARNESS
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Ignition 1 WHITE (+) IGNITION SWITCH HARNESS
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Starter 1 ORANGE (+) IGNITION SWITCH HARNESS
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. All Door Trigger 2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image.
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Domelight Super YELLOW (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. LF Latch YELLOW (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. RF Latch GREEN (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. LR Latch RED (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. RR Latch BLACK (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Trunk Trigger WHITE (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Hood Trigger RED / WHITE (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Alarm Disarm GREEN/ RED (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Alarm Arm GRAY/BLUE (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Parking Lights YELLOW & BROWN (+) VEHICLE FUSEBOX
Note for all door trigger reads: Use Individual wires and diode isolate.
Note for parking lights reads: Use both wires and diode isolate.
Remote Start info to follow on next post.
Posted: July 23, 2011 at 7:42 PM / IP Logged
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Accessory 1 LIGHT GREEN (+) IGNITION SWITCH HARNESS
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Anti-Theft Type UNIVERSAL IMMOBILIZER
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Key Sense RED / WHITE (OPEN) IGNITION SWITCH HARNESS 2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image.
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Tachometer GREEN / WHITE (AC) AT INJECTOR #1 2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image.
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Speed Sense WHITE/ BLUE (AC) IN HARNESS TO GAUGES 2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image.
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Parking Lights YELLOW & BROWN (+) VEHICLE FUSEBOX 2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image.
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Brake Lights RED (+) AT SWITCH ABOVE BRAKE PEDAL
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Reverse Lights WHITE (+) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Horn GREEN (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Alarm Indicator ORANGE (-) AT VEHICLE FUSEBOX
2011 Mitsubishi Outlander Sport Alarm/Remote Start Wiring -- posted image. Rear Defrost BLUE
Notes to follow
Posted: July 23, 2011 at 7:45 PM / IP Logged
Defrost wire also powers heated mirrors.
Note on keysense wire     THIS WIRE RESTS AT GROUND AND IS AN OPEN CIRCUIT WITH THE KEY INSERTED
Tach wire   ALSO AT ECM MODULE TO DRDIVER SIDE OF AIRCLEANER, PIN #2
VSS or Speed Sense wire    ALSO RED / GREEN ON VEHICLES WITH FACTORY NAVIGATION
Parking Lights once again reads    MUST USE BOTH WIRES AND DIODE ISOLATE EACH WIRE,
kendukes
Posted: July 24, 2011 at 7:17 AM / IP Logged
Thanks!
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
