2006 avalanche
snoboa13
Posted: September 15, 2011 at 9:43 AM / IP Logged
I need the stereo wiring and remote start wiring for a 2006 Avalanche can anyone help?
clarence1996
Member - Posts: 15
Posted: September 15, 2011 at 10:09 AM / IP Logged
Battery ORANGE (+) RADIO HARNESS
Accesory
Ground BLACK/ WHITE (-) RADIO HARNESS
Illumination BROWN (+) RADIO HARNESS
Dimmer GRAY (+) RADIO HARNESS
Power Antenna DARK GREEN (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) DARK GREEN
RF Speaker (+) LIGHT GREEN
RF Speaker (-) ORANGE / BLACK
LR Speaker (+) BROWN
LR Speaker (-) DARK GREEN / WHITE
RR Speaker (+) DARK BLUE
RR Speaker (-) BLACK
Amp Location UNDER CENTER CONSOLE
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
 12volts red (40A), red (40A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition pink   +   ignition harness
Second Ignition white   +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a
remote start system.
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   ignition harness
Power Lock use 457G or 456G module
Notes: If Directed module 457G or 456G is not available, refer to DirectFax document 1601.
Power Unlock see power lock
Lock Motor gray   5wi driver door module in door
Unlock Motor tan   5wi driver door module in door
Parking Lights+ brown   +   driver kick panel
Parking Lights- gray/black   -   switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white   -   hazard switch
Turn Signal(L) dk. green   +   turn signal switch
Turn Signal(R) lt. green   +   turn signal switch
Reverse Light lt. green   +   BCM, black plug, pin F
Door Trigger see notes   -   see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and
diode isolate each.
Dome Supervision gray/black   +   BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory
alarm disarm
Tachometer white   ac   instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Wait to start N/A
Brake Wire white   +   brake pedal switch
Parking Brake lt. blue   -   switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black   -   switch or BCM, gray plug, pin B9
Memory Seat 1 red   +   driver door module in door
Memory Seat 2 pink   +   driver door module in door
Memory Seat 3 N/A   +
Interface Module: Category:
Required:
Yes Type:
Passlock 2
Part #: 457G, 555L, or 555T
Notes: The Passlock 2 wire colors are yellow, black, and RED / white (not used).
TheWire1
Platinum - Posts: 13,725
Posted: September 15, 2011 at 5:24 PM / IP Logged
Are you replacing your radio? If so, I highly recommend purchasing the appropriate wiring harness so you do not have to cut the plug off of your wiring.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
