chevy suburban 2011
esl_install
Posted: December 22, 2011 at 9:07 AM / IP Logged
I need the wiring information for alarm and remote start.
reyhb
Member - Posts: 24
Posted: December 22, 2011 at 11:56 AM / IP Logged
Remote Start
Battery RED / BLACK(+)VEHICLE INTERIOR FUSE BOX
Ignition 1 PINK(+)IGNITION SWITCH HARNESS
Ignition 2 WHITE(+)IGNITION SWITCH HARNESS
Accessory 1 BROWN OR YELLOW(+)IGNITION SWITCH HARNESS
Starter 1 YELLOW/BLACK(+)AT MODULE UNDER HOOD BEHIND DRIVER HEADLIGHT***Not for remote start
Starter 2 WHITE(+)IGNITION SWITCH HARNESS*** USE A 1.3K OHM RESISTOR FOR STARTER
Anti-Theft Type -GM PASSKEY III® ANTI-THEFT SYSTEM
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense PINK/BLACK OR PINK(+)IGNITION SWITCH HARNESS
Tachometer WHITE(-)AT IGNITION COIL
Crankshaft Sensor WHITE/ BLACK(AC)AT ECM MODULE BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD **PLUG C2 - PIN #68
Camshaft Sensor DARK BLUE/WHITE(AC)AT ECM MODULE BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD PLUG C2 - PIN #64
Speed Sense YELLOW/BLACK(AC)AT ECM MODULE UNDER HOOD ON DRIVER FENDER ** BLACK PLUG PIN #57
Parking Lights LIGHT BLUE(-)AT BCM MODULE UNDER DRIVER DASH
Brake Lights LIGHT BLUE/WHITE(+)AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights DARK BLUE(+)AT BCM MODULE UNDER DRIVER DASH
Horn TAN(-)AT BCM MODULE UNDER DRIVER DASH
reyhb
Member - Posts: 24
Posted: December 22, 2011 at 12:10 PM / IP Logged
Alarm
All Door TriggerGRAY/BLACK(+)AT BCM MODULE UNDER DRIVER SIDE DASH** SOME VEHICLES MAY NOT BE EQUIPPED WITH THIS LIGHT, IN THIS CASE YOU MUST USE ALL FOUR DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Domelight Supervision GRAY(+)AT BCM MODULE UNDER DRIVER DASH
LF LatchGRAY/BLACK(-)AT MODULE IN DRIVER DOOR** MAY BE BROWN ON SOME MODELS
RF LatchTAN/WHITE(-)AT MODULE IN PASSENGER DOOR **MAY BE BLACK/ WHITE ON SOME MODELS
LR LatchLIGHT BLUE/BLACK(-)AT BCM MODULE UNDER DRIVER DASH ** PINK PLUG PIN #15
RR LatchLIGHT GREEN/ BLACK(-)AT BCM MODULE UNDER DRIVER DASH **PINK PLUG PIN #14
Hood TriggerPINK/BLACK(-)AT BCM MODULE UNDER DRIVER DASH ** BLACK PLUG PIN #17, NOT ON ALL MODELS
Alarm DisarmLIGHT GREEN(-)AT MODULE IN DRIVERS DOOR
Parking LightsLIGHT BLUE(-)AT BCM MODULE UNDER DRIVER DASH
Data BusDARK GREEN(-)AT OBD 2 PLUG
reyhb
Member - Posts: 24
Posted: December 22, 2011 at 12:16 PM / IP Logged
Forgot to add for Starter Kill use only starter 1 yellow/black(+) wire
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
