audi a6 2001
munius
Member - Posts: 14
Posted: May 02, 2012 at 6:07 PM / IP Logged
Hi there. I want to instal remote start in my audi a6 2.5tdi. Is any one knows the wirring for this car, Its right hand drive car.
Thanks.
Posted: May 03, 2012 at 5:49 AM / IP Logged
Yes I do thanks.
Unless you've done many of these, don't even think about it, take it to a pro.
munius
Member - Posts: 14
Posted: May 03, 2012 at 1:23 PM / IP Logged
well I have done on 2005 X5 and m3 and some others bmw. Wass strait forward, and it works fine. Now have finished, central lock problems fix on my audi, which wass eletrical problem.
Posted: May 03, 2012 at 1:33 PM / IP Logged
Similar in many ways to the BMW but harder to get at and more complex, typical Audi.
Look in the Downloads/Manuals section look for Audi A6, I've posted the nearest year right hand drive (UK spec) and US spec 2001, left hand drive.
I've picked up the locks behind the driver's kickpanel and left and right door triggers in the left and right kick panel, diode separate.
The best by-pass is the 556U, wired as alternative method 2, discard the loop.Use the black valet key from a dealer but make sure it's programmed to that car. US specifies double pulse for unlock, that shouldn't apply to a UK car.
Extend lock time to close the windows and roof.
Alternative for lock and unlock is the at the locking vacuum pump in the rear.
munius
Member - Posts: 14
Posted: May 03, 2012 at 1:47 PM / IP Logged
No vacum in my car, which it makes life easy. Thanks any way.
munius
Member - Posts: 14
Posted: May 03, 2012 at 1:59 PM / IP Logged
Howie!! I just have checked your manuals, you have done a very nice job here. Thanks again mate ;)
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
