2004 Subaru WRX Alarm/Remote Start Wiring
slamed civic
Posted: May 05, 2003 at 1:36 PM / IP Logged
If anybody has a diagram for 2004 Subaru WRX i need to do an alarm on that so can any body help me if you know the car or the diagram
2004 Subaru WRX Alarm/Remote Start Wiring -- posted image.
JWorm
Platinum - Posts: 2,208
Posted: May 05, 2003 at 9:04 PM / IP Logged
Here's a diagram for an 03....should be the same
12volts      BLACK/ white to white       +       ignition harness
Starter      BLACK / YELLOW to WHITE/ blk       +       ignition harness
Second Starter      N/A
Ignition      black to green       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ blue to yellow       +       ignition harness
Second Accessory      N/A
Keysense      WHITE/ red       +       ignition harness
Power Lock      RED / white       -       keyless entry module
Notes: The keyless entry module is to the left of the steering column.
Power Unlock      yellow/red       -       keyless entry module
Lock Motor      lt. GREEN/ black to orange       5wi      driver kick, door harness
Unlock Motor      RED / white to red       5wi      driver kick, door harness
Parking Lights+      orange       +       headlight switch
Parking Lights-      BLACK/ white       -       headlight switch
Notes: The negative parking light wire only functions with the ignition on.
Hazards      same as turn signals
Turn Signal(L)      BLACK/ green       +       steering column
Turn Signal(R)      lt. GREEN/ black       +       steering column
Reverse Light      BROWN / yellow       +       driver kick, harness to rear
Door Trigger      yellow       -       keyless entry module
Dome Supervision      use door trigger
Trunk/Hatch Pin      yellow/red       -       keyless entry module
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      factory remote only
Tachometer      green       ac       instrument cluster or ECM
Notes: The ECM (Engine Control Module) is behind the passenger side dash.
Wait to start      N/A
Brake Wire      WHITE/ black       +       brake pedal switch
Parking Brake      pink       -       parking brake switch
Horn Trigger      RED / green       -       steering column
You have a 5 speed I assume?? One thing that is great about the WRX is the cars ECU had a wire called a Neutral Position Sensor. It can be tied into a remote starter so the car will only remote start in neutral. If interested, I could explain how it could be done.
Check out http://forums.nasioc.com/forums/ for info on the car.
I have an 02 that was almost totaled last week. Sideswiped pulling into my work. Second time I've been hit in 5 months, so I'm going to get rid of it after its fixed. I think its jinxed.
Here's an old post I did on the WRX last year.
Any specific wiring questions on the car?....I probably know the answer.
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
