2009 seat ibiza wiring for car alarm
lysfys
Posted: August 08, 2012 at 9:41 PM / IP Logged
hello as the title says i need the vehicle wiring to install an alarm in this car if someone can help thanks in advance
Posted: August 10, 2012 at 1:38 AM / IP Logged
Use and install as 2009 Golf/Jetta, since I hate them (French, Spanish Italian, build quality and electrics)I'm not sure whether this is Polo based or Golf based. If Golf based, there you go, check in Wiki.
lysfys
Posted: August 14, 2012 at 1:07 PM / IP Logged
thanks a lot i will check
Posted: August 14, 2012 at 4:03 PM / IP Logged
Actually it's closer to the Euro Polo.
Bare with me a couple of days and I will give you all the tech info.
Posted: August 14, 2012 at 4:30 PM / IP Logged
Now in Downloads/Manual section on this site, enter Seat Ibiza 2009.
Note 1. There's a mistake on their lists, they list the indicators as WHITE/ black and BLACK/ green, actually they are BLACK/ white and BLACK/ green.
If you would rather use lights, check the grey wires at the light switch, though if yours is a European vehicle, indicators will look better.
Note 2. They list the trunk/hatch pin, it needs diode blocking, between your joint and the front of the car, 1N4004 diode, band towards the joint.
Also under the hood, BLACK/ green but be careful, on the Polo one is the hood switch the other the direction indicator wire so TEST(also same colour as Polo, NOT listed on the info, trace back from the switch in the hood shut, again the same diode, this time between the joint to your wire and the car this time, again band towards the joint. Not needed on the dome though.*
Lastly depending on the alarm, if you have a 2 wire low neg output for lock and unlock you will need relays to drive through the required resistor. Not needed if you have a 6 wire relay driven lock output.
This vehicle has a sleeper circuit. Hatch and hood triggers go to the BCM as inputs and need diodes to prevent "wake-up" spikes triggering the alarm. The dome light is on the BCM output and doesn't need the diode.
lysfys
Posted: August 14, 2012 at 5:33 PM / IP Logged
ok thanks howie!!
glenpring
Posted: March 07, 2014 at 8:19 AM / IP Logged
hi any chance that the wiring is the same for a seat ibiza 2003? i need to disconnect the hazard light from the alarm as they go off all the time. until i can afford to get it sorted properly.
howie (aka: harryharris)
Silver - Posts: 355
Posted: March 07, 2014 at 10:32 AM / IP Logged
Look for the factory alarm module, probably black to the right of steering column, 2 plugs cut off the BLACK/ green and BLACK/ white adjacent wires.
Test before boxing up.
