DEI 555I and 2002 Honda CR-V
street tuner 9
Member - Posts: 13
Posted: May 05, 2003 at 8:30 PM / IP Logged
I am having a weird issue with my Clifford Matrix RSIII and 555I immobilizer bypass. The install is complete and everything works fine except for the flashing green key light on the dash:
1) Remote start the vehicle.
2) Insert key into cylinder to "on" position.
3) Put vehicle into Drive.
4) After about 2-5 minutes of driving, the green key light will begin to flash. This will persist until I turn off the engine.
I have no idea how to remedy this as there is a lag of several minutes prior to the light beginning to flash. Any ideas or suggestions would be appreciated! Thanks:)
street tuner 9
Member - Posts: 13
Posted: May 05, 2003 at 8:35 PM / IP Logged
Oops... for some reason this got added to the wrong forum. Can someone move this post to the Car Security forum? Thanks!
ergoaudio
Member - Posts: 11
Posted: May 05, 2003 at 8:52 PM / IP Logged
you will more than likely need to have your keys reprogrammed.  this sometimes happens in certain vehicles that require a loop around the gin cylender.
If your ears aren't bleeding... it's not loud enough.
street tuner 9
Member - Posts: 13
Posted: May 05, 2003 at 9:40 PM / IP Logged
The strange thing is that I can still start the car with my existing keys and the flashing light problem does not occur. This will only happen when I use the remote start.
CruisinS&S
Copper - Posts: 225
Posted: May 06, 2003 at 5:45 PM / IP Logged
try to reprogram the 555i with a different key
Cruisin Security And Sounds
