2012 Volkswagen Passat Alarm/Remote Start/Stereo Wiring
brsexton
Copper - Posts: 53
Posted: September 25, 2012 at 3:41 AM / IP Logged
Hello. I am looking for wiring information for the 2012 VW Passat to do remote start. Thanks.
tommy...
Gold - Posts: 1,901
Posted: September 25, 2012 at 8:32 AM / IP Logged
2012 Volkswagen Passat     DirectWire 2.0 Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     red (40A)     +     VESCM, black 52 pin plug, pin 1
The VESCM (Vehicle Electrical System Control Module) is the relay box under the driver dash.
Second 12 Volts     RED / yellow (40A)     +     VESCM, brown 52 pin plug, pin 42
Starter     RED / black (without push-button start)     +     VESCM, brown 52 pin plug, pin 14
Second Starter     pur/yel (sw1), pur/blk (sw2) (push-button start)     - resistor     start system button, black 4 pin plug, pins 3 and 4
Ignition     black     +     VESCM, brown 52 pin plug, pin 31
Second Ignition     RED / blue     +     VESCM, white 52 pin plug, pin 14
Third Ignition     N/A
Accessory     BLACK/ purple (for accessory sense only)     +     VESCM, white 52 pin plug, pin 28 or black 52 pin plug, pin 3
Second Accessory     N/A
Third Accessory     N/A
Keysense     PURPLE / red (push-button start only)     +     VESCM, brown 52 pin plug, pin 13
Data Bus     N/A
Can Bus High     ORANGE / green     data     VESCM, brown 52 pin plug, pin 15
Can Bus Low     ORANGE / brown     data     VESCM, brown 52 pin plug, pin 16
Can Bus Sw     N/A
Power Lock     BROWN / green     -     Driver Door Module, gray 32 pin plug, pin 32
Power Unlock     same as power lock     - 180 ohms
Lock Motor     blue/green     5 wire     VESCM, white 52 pin plug, pin 7
Driver Unlock Motor     purple     5 wire     Driver Door Module, black 20 pin plug, pin 12
Passenger Unlock Motor     BROWN / yellow     5 wire     VESCM, white 52 pin plug, pin 8
Parking Lights (-)     N/A
Parking Lights (+)     gray / YELLOW     +     VESCM, black 52 pin plug, pin 19
The VESCM (Vehicle Electrical System Control Module) is the relay box under the driver dash. Must interrupt the autolights wire to activate the parking lights.
Hazards     BROWN / red     -     VESCM, brown 52 pin plug, pin 7
Turn Signal (Left)     gray/white (F); BLACK/ white (R)     +     VESCM, black 52 pin plug, pin 10; brown 52 pin plug, pin 51
Turn Signal (Right)     gray/brown (F); BLACK/ red (R)     +     VESCM, brown 52 pin plug, pin 50; black 52 pin plug, pin 9
Headlight     WHITE/ black     +     VESCM, black 52 pin plug, pin 22
AutoLights     purple (interrupt to turn off autolights)     +     VESCM, black 52 pin plug, pin 20
Reverse Light     blue/purple     +     VESCM, black 52 pin plug, pin 28
Left Front Door Trigger     BROWN / yellow     -     Driver Door Module, black 20 pin plug, pin 7
Right Front Door Trigger     BROWN / yellow     -     Passenger Door Module, black 20 pin plug, pin 7
Left Rear Door Trigger     BLACK/ gray     -     VESCM, black 52 pin plug, pin 41
Right Rear Door Trigger     BLACK/ green     -     VESCM, black 52 pin plug, pin 30
Dome Supervision     RED / white     -     VESCM, brown 52 pin plug, pin 10
Trunk/Hatch Pin     BROWN / blue or BROWN / black     -     VESCM, black 52 pin plug, pin 29
Rear Glass Pin     N/A
Hood Pin     BROWN / green     -     VESCM, black 52 pin plug, pin 14
Trunk/Hatch Release     purple (rear handle switch)     -     VESCM, black 52 pin plug, pin 13
Trunk Release Motor     RED / blue     5 wire     VESCM, white 52 pin plug, pin 11
Fuel Door Release     locks/unlocks along with doors
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     GREEN / WHITE (driver door key lock)     -     Driver Door Module, black 20 pin plug, pin 16
Factory Alarm Disarm     same as factory alarm arm     - 180 ohms
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     PURPLE / stripe (2.5L), BROWN / stripe (3.6L, 2.0L)     ac     any fuel injector, 2 pin plug, pin 2
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     PURPLE / white     -     VESCM, brown 52 pin plug, pin 30
Fuel Pump     RED / white (2.5L), blue/red (2.0L diesel)     +     fuel pump relay on upper VESCM
The VESCM (Vehicle Electrical System Control Module) is the relay box under the driver dash. On 3.6L models, it is BLACK/ green (+) in the driver kick, harness to rear.
Rear Defroster     BLACK/ green     - latched     VESCM, white 52 pin plug, pin 22
Mirror Defroster     yellow     -     Driver Door Module, gray 32 pin plug, pin 28
Left Front Heated Seat     (CAN and LIN bus)
Right Front Heated Seat     (CAN and LIN bus)
Speed Sense     (wheel speed sensor)
Brake Wire     BLACK/ red (functions with ignition on only)     +     VESCM, brown 52 pin plug, pin 17
Parking Brake     BROWN / yellow     -     parking brake switch, black 2 pin plug, pin 1
Horn Trigger     RED / brown     -     VESCM, white 52 pin plug, pin 41
Wipers     WHITE/ red     -     VESCM, white 52 pin plug, pin 23
Left Front Window (Up/Down)     use factory alarm arm/disarm
Right Front Window (Up/Down)     see left front window
Left Rear Window (Up/Down)     see left front window
Right Rear Window (Up/Down)     see left front window
Sun Roof (Open/Close)     WHITE/ purple (tilt up/down) (func w/ign on only)     - resistor     sunroof switch, 4 pin plug, pin 4
Sun Roof (Limit/Close)     N/A
Memory Seat 1     RED / black     - resistor     memory switch or Driver Seat Module, 32 pin plug, pin 12
Memory Seat 2     same as memory seat 1     - resistor
Memory Seat 3     yellow/black     - resistor     memory switch or Driver Seat Module, 32 pin plug, pin 28
Radio 12V     RED / yellow     +     radio, 16 pin plug, pins 15 and 16
Radio Ground     brown     -     radio, 16 pin plug, pin 12
Radio Ignition     (Infotainment CAN)
Radio Illumination     (Infotainment CAN)
Factory Amp Turn-on     (Infotainment CAN)
Power Antenna     N/A
Left Front Speaker (+/-)     BROWN / green - BROWN / blue or green - brown     +,-     radio, 8 pin plug, pins 3 and 7
If equipped, the amplifier is under the driver seat. On vehicles with amplifier, the speaker wires are BROWN / green - BROWN / blue (woofer); blue/black - WHITE/ black (midrange); white - WHITE/ black (tweeter) at the amplifier, 38 pin plug, pins 18 and 6; 13 and 14; 8 and 20.
Right Front Speaker (+/-)     BROWN / red - BROWN / black or blue - brown     +,-     radio, 8 pin plug, pins 2 and 6
If equipped, the amplifier is under the driver seat. On vehicles with amplifier, the speaker wires are BROWN / red - BROWN / black (woofer); RED / gray - BROWN / gray (midrange); gray - gray/black (tweeter) at the amplifier, 38 pin plug, pins 15 and 3; 12 and 11; 19 and 7.
Left Rear Speaker (+/-)     RED / white - BROWN / white or white - brown     +,-     radio, 8 pin plug, pins 4 and 8
If equipped, the amplifier is under the driver seat. On vehicles with amplifier, the speaker wires are RED / white - BROWN / white at the amplifier, 38 pin plug, pins 9 and 21.
Right Rear Speaker (+/-)     RED / purple - BROWN / purple or yellow - brown     +,-     radio, 8 pin plug, pins 1 and 5
If equipped, the amplifier is under the driver seat. On vehicles with amplifier, the speaker wires are RED / purple - BROWN / purple at the amplifier, 38 pin plug, pins 22 and 10.
Center Channel (+/-)     N/A
Subwoofer (+/-)     WHITE/ red - BROWN / red (1); gray/red - gray/brn (2)     +,-     amplifier, 38 pin plug, pins 16 and 4; 5 and 17
Aux. Audio Input Left (+/-)     yellow - green     +,-     radio, 12 pin plug, pins 1 and 2
Aux. Audio Input Right (+/-)     gray - green     +,-     radio, 12 pin plug, pins 7 and 2
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular
Left Front Speaker     6.5     3.5     left front door
Left Front Tweeter     1     1     left front dash
Right Front Speaker     6.5     3.5     right front door
Right Front Tweeter     1     1     right front dash
Left Rear Speaker     6.5     3.5     left rear door
Left Rear Tweeter     1     1     left rear door
Right Rear Speaker     6.5     3.5     right rear door
Right Rear Tweeter     1     1     right rear door
Center Channel     N/A
Subwoofer   under rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
M.E.C.P & First-Class
brsexton
Copper - Posts: 53
Posted: September 25, 2012 at 6:41 PM / IP Logged
Thanks so much!!!
tommy...
Gold - Posts: 1,901
Posted: September 26, 2012 at 10:53 AM / IP Logged
You're Welcome...
phxcliff
Posted: July 01, 2014 at 1:37 PM / IP Logged
Is this wiring the same for the 2012 Passat TDI?
Thanks.
Posted: July 02, 2014 at 2:09 AM / IP Logged
Don't knock yourself out, use a DB-ALL2 or something similar from Fortin, go to the Xpresskit site, enter make model year then select installation sheet and you'll see.
Sunday, November 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
