2010 Ford Mustang Alarm/Remote Start Wiring
koncept21
Posted: December 09, 2012 at 2:02 PM / IP Logged
Hello i recently purchased a Viper 5904 alarm and need a wiring diagram for my 2010 ford mustang. I was using the same one for the 2012 but i believe its not the same one. I need to also find out the location of the 52 pin plug. Thanks for the help
shortcircuit161
Silver - Posts: 556
Posted: December 09, 2012 at 11:57 PM / IP Logged
2010 and up should be the same wiring.
DIRECTWIRE™ WIRING INFORMATION - FORD / MUSTANG / 2010 / Remote Start
[PRINT THIS PAGE]
12volts      red (80A)      +      SJB, black 1 pin plug (G), pin 1
Notes: The SJB (Smart Junction Box) is in the passenger kick.
Starter      blue/white      +      ignition switch, black 7 pin plug, pin 7
Second Starter      N/A
Ignition      gray/purple      +      ignition switch, black 7 pin plug, pin 1
Second Ignition      N/A
Third Ignition      N/A
Accessory      PURPLE / green      +      ignition switch, black 7 pin plug, pin 6
Second Accessory      N/A
Keysense      blue/gray      +      ignition switch, black 7 pin plug, pin 5
Power Lock      blue/green      -      driver kick or SJB, gray 26 pin plug (C), pin 17
Power Unlock      yellow/purple      -      driver kick or SJB, gray 26 pin plug (C), pin 4
Notes: The inertia fuel shutoff switch is in the driver kick.
Lock Motor      gray/brown      5 wire      driver kick or SJB, black 32 pin plug (D), pin 6
Unlock Motor      blue/green      5 wire      driver kick or SJB, black 32 pin plug (D), pin 28
Parking Lights+      PURPLE / white      +      SJB, gray 13 pin plug (E), pin 6
Parking Lights-      gray      -      headlight switch or SJB, black 52 pin plug (B), pin 31
May need to interrupt the headlight switch ground when triggering this wire. It is BLACK/ purple at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Hazards      BROWN / yellow      -      hazard switch or SJB, black 52 pin plug (B), pin 48
Turn Signal(L)      blue/green (F)      +      SJB, black 26 pin plug (F), pin 21
The rear turn signals are gray/brown, BROWN / purple, and WHITE/ green at the BCM B, black 24 pin plug, pins 4, 3, and 2.
The BCM B (Body Control Module B) is in the right side of the cargo compartment.
Turn Signal(R)      yellow/purple (F)      +      SJB, black 26 pin plug (F), pin 23
The rear turn signals are PURPLE / orange, brown, and gray/purple at the BCM B, black 24 pin plug, pins 16, 15, and 14.
Reverse Light      GREEN/ brown      +      BCM B, black 24 pin plug, pin 5
Notes: The BCM B (Body Control Module B) is in the right side of the cargo compartment.
On vehicles with auto-dimming rearview mirror, can also use gray/brown (+) in the passenger kick, harness to rear.
Door Trigger      GREEN/ purple      - N.C.      driver kick or SJB, gray 26 pin plug (C), pin 14
Dome Supervision      gray/purple      +      SJB, gray 14 pin plug (A), pin 9
Trunk/Hatch Pin      gray/orange      - N.C.      SJB, gray 26 pin plug (C), pin 16
Hood Pin      blue/orange      - N.C.      hood switch or SJB, black 26 pin plug (F), pin 10
Trunk/Hatch Release      brn/yel (coupe), brn/yel or brn/pur (convertible)      -      release switch or SJB, gray 26 pin plug (C), pin 20
Power Sliding Door      N/A
Factory Alarm Arm      yellow/gray (driver door key lock)      -      driver kick or SJB, gray 26 pin plug (C), pin 9
Factory Alarm Disarm      GREEN/ purple (driver door key unlock)      -      driver kick or SJB, gray 26 pin plug (C), pin 8
Disarm No Unlock      see factory alarm disarm
Tachometer      gn/bu, gy/ye, pu/gy, ye/og, bn, gn/wh, gy/bn, pu/o      ac      any fuel injector, black (V6) or gray (V8) 2 pin plug, pin 1
Wait to start      N/A
Brake Wire      PURPLE / white      +      brake switch or SJB, black 52 pin plug (B), pin 40
Parking Brake      WHITE/ purple      -      parking brake switch or SJB, gray 26 pin plug (C), pin 1
Horn Trigger      blue/white      -      horn switch or SJB, black 52 pin plug (B), pin 41
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Modules: Not Available
