2003 Expedition
AdamRosen
Member - Posts: 8
Posted: May 08, 2003 at 8:28 AM / IP Logged
Does anyone have a wiring guide for a 2003 Ford Expedition? Thank you in advance for your help.
Adam
Patel
Copper - Posts: 86
Posted: May 08, 2003 at 11:24 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|GREEN/ purple        |+ |ignition harness            |
|          STARTER|RED / blue            |+ |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|        IGNITION|blue/green          |+ |ignition harness            |
| SECOND IGNITION|                    |   |                            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|BLACK/ green        |+ |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|pink / YELLOW        |- |driver kick panel           |
|     POWER UNLOCK|pink/green          |- |driver kick panel           |
|       LOCK MOTOR|pink/black          |   |driver kick panel           |
|     UNLOCK MOTOR|RED / orange          |   |driver kick panel           |
|    DISARM DEFEAT|pink/orange        |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |driver kick panel           |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|BLACK/ lt. blue      |+ |driver kick panel           |
| DOME SUPERVISION|                    |   |                            |
| TRUNK/HATCH PIN|                    |   |                            |
|        HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|WHITE/ pink          |+ |passenger kick panel        |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|NOT RED / green       |   |any ignition coil           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|lt. green           |+ |brake pedal switch          |
|     HORN TRIGGER|dk. blue            |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|                    |   |                            |
| RF WINDOW UP/DN|                    |   |                            |
| LR WINDOW UP/DN|                    |   |                            |
| RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle is equipped with PATS (Passive Anti-Theft System). Use DEI module 555U to over-ride during remote start.
