2009 toyota corolla japan made
ajan246
Member - Posts: 22
Posted: February 20, 2013 at 10:36 AM / IP Logged
Hey everyone,
Can someone post a full and accurate wiring chart for an alarm remote start. The ones posted are not accurate. The only one that is, is listed by Mike M2 but it is not complete. ie domelight supervision etc.
Posted: February 21, 2013 at 1:31 AM / IP Logged
Use what you have and test.
If your dome light stays on what you shut the door for up to a minute but goes out within a second or so when you lock it you won't need dome supervision for a start.
Frankly it isn't a vehicle I'd need a crib sheet for it's a no brainer install.
Possibly not even an immobiliser! So no by-pass needed.
Ignition wiring at switch.
Lights, NEG at steering column.Hazards if preferred, 1 wire if switched to ground, probably green primary at the hazard switch.
Door triggers, dome light switched feed.
Trunk triggers at trunk catch, if hatchback it will share with the door triggers.
Pin switch for hood.
Lock/unlock at a white plug, NEG driver kickwell.
Job done.
You might have two ignitions and two starters, check.
