2013 Chevrolet Malibu Alarm/Remote Start Wiring
chevyhhrss400
Posted: February 27, 2013 at 11:26 PM / IP Logged
Looking for wiring info for alarm/remote start
And audio system info
Car has remote start so just was better alarm added
Car came with chevy new myLink system
Can it be wired for dvd video playback?
Want to add back up camera also
And add amplifier to stock headunit. Its not premium setup though
chevyhhrss400
Posted: February 28, 2013 at 9:43 AM / IP Logged
Noone has schematic in this vehicle?
wirewise
Moderator - Posts: 489
Posted: June 03, 2013 at 9:56 AM / IP Logged
2013 CHEVROLET MALIBU 4DR SEDAN WITH 2.0L T/C ENGINE AND STANDARD 6-SPEAKER AUDIO SYSTEM
Security
     WIRE COLOR POLARITY LOCATION
     Battery RED / BLUE (+) IGNITION SWITCH HARNESS
     Ignition 1 VIOLET (+) IGNITION SWITCH HARNESS
     Starter 1 GREEN/ YELLOW (+) AT KEYLESS ENTRY MODULE HIGH IN PASSENGER KICKPANEL TO RIGHT OF GLOVEBOX
     All Door Trigger GRAY (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Domelight Super GRAY (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     LF Latch GRAY (-) IN HARNESS AT DOOR LATCH IN DOOR
     RF Latch GRAY (-) IN HARNESS AT DOOR LATCH IN DOOR
     LR Latch BROWN / WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     RR Latch GRAY/BLACK (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Trunk Trigger VIOLET (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Hood Trigger BROWN / GREEN (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Alarm Disarm BLUE/VIOLET (-) IN HARNESS AT DOOR LATCH IN FRONT LEFT DOOR
  PULSE THIS WIRE TO INDICATE THE KEY BEING PRESENT IN THE DRIVERS DOOR TO TEMPORARILY DISARM THE FACTORY ALARM.
     Alarm Arm
  PULSE THE LOCK WIRE TWICE TO ARM THE FACTORY ALARM.
     Parking Lights GRAY (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Convenience
     Headlights-Lo WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Headlights-Hi WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     LF Pk Lt Bulb VIOLET/GRAY (+) AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb GRAY/BROWN (+) AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb VIOLET/GRAY (+) AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb GRAY/BROWN (+) AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights GREEN / WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     LF Hazrd Bulb BLUE/WHITE (+) AT FRONT LEFT DIRECTIONAL LIGHT
     RF Hazrd Bulb GREEN/ VIOLET (+) AT FRONT RIGHT DIRECTIONAL LIGHT
     LR Hazrd Bulb BLUE/WHITE (+) AT REAR LEFT DIRECTIONAL LIGHT
     RR Hazrd Bulb BLUE/VIOLET (+) AT REAR RIGHT DIRECTIONAL LIGHT
     Wipers-Lo BLACK (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Wipers-Hi GRAY (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Parking Brake BLUE/VIOLET (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Trnk Release YELLOW/BLUE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Remote Start
     Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
     Neutral Safety WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Brake Lights VIOLET/WHITE (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
  DO NOT USE THE WIRE(S) AT THE SWITCH ABOVE THE PEDAL AS THIS WILL AFFECT VEHICLE DYNAMICS CONTROLS.
     Reverse Lights GREEN / WHITE (+) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Horn GREEN (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Databus GREEN/ VIOLET (DATA) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Rear Defrost BROWN / VIOLET (+) IN HARNESS AT HVAC CONTROL MODULE AT REAR OF HVAC CONTROLS
     Modules
     WIRE LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock WHITE (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     PowerLock BROWN (-) AT BCM MODULE ABOVE DRIVERS KICKPANEL TO LEFT OF STEERING COLUMN
     Driver Mtr Unlock GRAY (REV) AT MOTOR IN DOOR
     Driver Mtr Lock BROWN / YELLOW (REV) AT MOTOR IN DOOR
     Pas Mtr Unlock GRAY (REV) AT MOTOR IN DOOR
     Pas Mtr Lock BROWN / YELLOW (REV) AT MOTOR IN DOOR
     LF Window Up GREEN/ GRAY OR GREEN / WHITE (REV) AT MOTOR IN DOOR
     LF Window Dn YELLOW/VIOLET OR GRAY (REV) AT MOTOR IN DOOR
     RF Window Up GREEN/ GRAY (REV) AT MOTOR IN DOOR
     RF Window Dn YELLOW/BLUE (REV) AT MOTOR IN DOOR
     LR Window Up BLUE/VIOLET (REV) AT MOTOR IN DOOR
     LR Window Dn YELLOW/BLUE (REV) AT MOTOR IN DOOR
     RR Window Up BLUE/GRAY (REV) AT MOTOR IN DOOR
     RR Window Dn GREEN/ BLACK (REV) AT MOTOR IN DOOR
     Sunroof Open BLUE/VIOLET (-) AT SUNROOF MOTOR ASSEMBLY ABOVE HEADLINER
  PULSE GROUND THROUGH A 98-OHM RESISTOR.
     Sunroof Close BLUE/VIOLET (-) AT SUNROOF MOTOR ASSEMBLY ABOVE HEADLINER
  PULSE GROUND THROUGH AN 830-OHM RESISTOR.
