2001 alfa romeo 147 wiring info?
slaphapy74
Posted: March 07, 2013 at 1:23 PM / IP Logged
I purchased a 2001 Alfa Romeo 147 with Euro Specs and plan to install a Viper 5704 Remote start/ Security System.   Does anyone have the Wiring Information for this Vehicle.
It's all fun and games until someone gets an eye poked out
tommy...
Gold - Posts: 1,901
Posted: March 07, 2013 at 3:26 PM / IP Logged
2001 Alfa Romeo 147     DirectWire 2.0 Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts
Second 12 Volts
Starter
Second Starter
Ignition
Second Ignition
Third Ignition
Accessory
Second Accessory
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock     blue/purple
Power Unlock     WHITE/ blue
Lock Motor
Driver Unlock Motor
Passenger Unlock Motor
Parking Lights (-)
Parking Lights (+)
Hazards
Turn Signal (Left)
Turn Signal (Right)
Headlight
AutoLights
Reverse Light
Left Front Door Trigger     blue     +     in driver door at door bulb
Right Front Door Trigger
Left Rear Door Trigger
Right Rear Door Trigger
Dome Supervision
Trunk/Hatch Pin     grey     +     at bulb
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Power Sliding Door (Left)
Power Sliding Door (Right)
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Left Front Heated Seat
Right Front Heated Seat
Speed Sense
Brake Wire
Parking Brake
Horn Trigger
Wipers
Left Front Window (Up/Down)     violet/black
Right Front Window (Up/Down)     WHITE/ red
Left Rear Window (Up/Down)
Right Rear Window (Up/Down)
Sun Roof (Open/Close)
Sun Roof (Limit/Close)
Memory Seat 1
Memory Seat 2
Memory Seat 3
Radio 12V
Radio Ground
Radio Ignition
Radio Illumination
Factory Amp Turn-on
Power Antenna
2000 Alfa Romeo 147     DirectWire 2.0 Vehicle Information
All Products
12 Volts
Second 12 Volts
Starter     brown     +     loom to column
Second Starter
Ignition     orange     +     loom to column
Second Ignition
Third Ignition
Accessory
Second Accessory
Third Accessory
Keysense
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock     light/blue pin35     -     see note
Power Unlock     light/blue pin17     -     see note
Lock Motor
Driver Unlock Motor
Parking Lights (-)
Parking Lights (+)
Hazards
Turn Signal (Left)     pin39,2,38,22     +     see note
Turn Signal (Right)     pin12,3     +     see note
Headlight
AutoLights
Reverse Light
Left Front Door Trigger     light blue / YELLOW pin21     +     same as locking
Dome Supervision
Trunk/Hatch Pin     BROWN / grey pin36     +     same as locking
Rear Glass Pin
Hood Pin
Trunk/Hatch Release
Trunk Release Motor
Fuel Door Release
Factory Alarm Arm
Disarm No Unlock
Trunk Alarm Shunt
Tachometer
Wait to Start
Neutral Safety
Clutch Pedal
Fuel Pump
Rear Defroster
Mirror Defroster
Speed Sense
Brake Wire
Parking Brake
Horn Trigger
Wipers
Left Front Window (Up/Down)     WHITE/ red     +     see note
Right Front Window (Up/Down)     violet/black     +     see note
Not alot of tech notes... put a 2000 as-well, though might be different.
M.E.C.P & First-Class
slaphapy74
Posted: March 07, 2013 at 10:58 PM / IP Logged
Looks like I will need to get the wire probes out. 2001 alfa romeo 147 wiring info? -- posted image.
Posted: March 07, 2013 at 11:23 PM / IP Logged
Pretty straight forward, you'll need a 556U as a by-pass, standard Fiat/Alfa colours at the ignition, usual Fiat/Alfa white and blue low neg lock/unlock.
Fuse/body control box for window lifts indicators/ door triggers, diode block for trunk and hood inputs (not even sure there is a hood input though).
If it's anything like the GTV I did recently, engine bay access is a nightmare though.
Also beware all trim panels, they break.
Being Fiat 3 and 4 mm hex bolt keys required, also the steering wheel cowling will probably be a nightmare.
There might be a white loose plug in the centre console, that's where a POS Meta alarm is sometimes dealer installed.
Gives you lock, unlock, ignition, power and ground door triggers and indicators.
