Here you go :
Radio 12V     BROWN / red     +     radio, black 24 pin plug, pin 1
Radio Ground     black     -     radio, black 24 pin plug, pin 13
Radio Ignition     (Infotainment CAN)
Radio Illumination     brown (without SYNC)     + dimmer     radio controls, 8 pin plug, pin 3
Factory Amp Turn-on     yellow/purple     +     radio, black 26 pin plug, pin 18
Power Antenna     yellow/orange     +     radio, black 24 pin plug, pin 2
Left Front Speaker (+/-)     white - WHITE/ brown     +,-     radio, black 24 pin plug, pins 22 and 10
On models with amplifiier, the speaker wires are white - WHITE/ brown (woofer); PURPLE / orange - yellow/orange (tweeter) at the amplifier in LF cargo floor, gray 16 pin plug, pins 2 and 10; 3 and 11.
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange     +,-     radio, black 24 pin plug, pins 23 and 11
On models with amplifiier, the speaker wires are WHITE/ purple - WHITE/ orange (woofer); GREEN/ orange - gray/orange (tweeter) at the amplifier in LF cargo floor, gray 16 pin plug, pins 6 and 14; 7 and 15.
Left Rear Speaker (+/-)     WHITE/ green or BROWN / green - BROWN / yellow     +,-     radio, black 24 pin plug, pins 21 and 9
On models with amplifiier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier in LF cargo floor, gray 16 pin plug, pins 4 and 12.
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, black 24 pin plug, pins 24 and 12
On models with amplifiier, the speaker wires are BROWN / white - BROWN / blue at the amplifier in LF cargo floor, gray 16 pin plug, pins 8 and 16.
Center Channel (+/-)     blue - PURPLE / green     +,-     radio, black 24 pin plug, pins 20 and 8
On models with amplifiier, the speaker wires are green - gray / YELLOW at the amplifier in LF cargo floor, gray 16 pin plug, pins 1 and 9.
Subwoofer (+/-)     purple - yellow (1); GREEN/ purple - gray (2)     +,-     amplifier in LF cargo floor, blue 16 pin plg, pins 1 and 9; 2 and 10
Aux. Audio Input Left (+/-)     blue/red - (shield) (without SYNC)     +,-     radio, black 24 pin plug, pins 17 and 6
Aux. Audio Input Right (+/-)     BROWN / red - (shield) (without SYNC)     +,-     radio, black 24 pin plug, pins 18 and 6
RSE Video (+/-)     blu-grn (rear view cam); brn-brn/yel (aux. video)     +,-     SYNC Mod/display, bk 54 pin plg, pins 14-15; 34-35
RSE Audio Left (+/-)     green - gray or blue - gray/orange (SYNC audio)     +,-     radio, black 26 pin plug, pins 12 and 25
RSE Audio Right (+/-)     purple - yellow or pur/grn - brn/wht (SYNC audio)     +,-     radio, black 26 pin plug, pins 13 and 26
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular  center of dash
Left Front Speaker     6 x 8     3.8     left front door
Left Front Tweeter    left front door
Right Front Speaker     6 x 8     3.8     right front door
Right Front Tweeter    right front door
Left Rear Speaker     6 x 8     4 - 5     left rear door
Left Rear Tweeter    left rear door
Right Rear Speaker     6 x 8     4 - 5     right rear door
Right Rear Tweeter    right rear door
Center Channel    top center of dash
Subwoofer    right side of cargo compartment
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Gary Sather
