1996 acura cl trunk pop
geffsmit
Posted: December 16, 2013 at 12:14 PM / IP Logged
Wiring up a trunk pop on an alarm. I understand that you have to wire up the trunk pop like a 5 wire door lock/unlock system. Diagram I had says the blue w/red wire at the alarm brain under the pass side seat needs to be cut in half and then wired up 5 wire. Did this.  Didn't work.  Any ideas on another location for a wire to grab or different way to make this work?
Thank you
G. Smith
smokeman1
Platinum - Posts: 1,589
Posted: December 16, 2013 at 3:41 PM / IP Logged
Might need to know what remote/alarm system you are working with and what wires you have going from what to what. I assume there is a relay in this somewhere.
