adding leds to an existing alarm
gary34
Member - Posts: 6
Posted: October 17, 2014 at 6:11 PM / IP Logged
I have a 2012 dodge avenger and want to add leds to the alarm so that they only come on when the system is armed. But dont know where the alarm is located or what i am doing
Posted: October 18, 2014 at 11:36 AM / IP Logged
OK, let's go to basics:-
Is your alarm controlled by buttons on the factory key or is there a separate remote control fob?
If separate is there an FCC number on the back or a name.
PS Have you confirmed that there's a factory alarm on board?
With apologies to Kreg.
gary34
Member - Posts: 6
Posted: October 18, 2014 at 7:44 PM / IP Logged
It is a factory alarm
gary34
Member - Posts: 6
Posted: October 18, 2014 at 7:51 PM / IP Logged
the fob and key is all in one
gary34
Member - Posts: 6
Posted: October 18, 2014 at 8:00 PM / IP Logged
I do have the fcc id that was mentioned if that helps
Posted: October 19, 2014 at 1:35 AM / IP Logged
Then you first contact a Chrysler dealer and see what they say.
One doesn't mess with factory alarms without a circuit diagram.
If there's a factory LED you might be able to parallel wire others into the circuit but you'd need to know the supply voltages, usually around 2.5VDC.
Frankly not a job I'd bother with on a modern car.
Platinum - Posts: 7,827
Posted: October 19, 2014 at 5:38 AM / IP Logged
You could buy and install one of those two wire pseudo alarm blinking LED's or strobe strips off EBay for $5.
Easy install and it would start blinking whenever the key was in the OFF position, regardless of the Factory Alarm being set or not.
gary34
Member - Posts: 6
Posted: October 19, 2014 at 6:25 AM / IP Logged
Ok thank you
Posted: October 19, 2014 at 6:26 AM / IP Logged
Wire the red to a constant 12V+ the black to ignition.
gary34
Member - Posts: 6
Posted: October 19, 2014 at 6:29 AM / IP Logged
Couldnt i do that with the led strip that i already have ? If so how? I do know the ground attaches to the car but not sure where to put the posititive
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
