mazda5
shaun wyatt
Member - Posts: 8
Posted: November 10, 2014 at 7:56 AM / IP Logged
Hi,my keyfob on my mazda5 2006 is not working and a replacement is to much money.i have bought a aftermarket keyless entry system but i cannot find what lock type i have.i have 9 wires coming from the lock but thw wiring diagram does not make it clear which ones are for the central locking.I have found a wire which unlocks the car when i earth it out
Thanks Shaun
shaun wyatt
Member - Posts: 8
Posted: November 10, 2014 at 9:09 AM / IP Logged
mazda5 -- posted image.
This is the wiring diagram
Thanks Shaun
shaun wyatt
Member - Posts: 8
Posted: November 10, 2014 at 9:12 AM / IP Logged
Sorry, try this link
http://am.mazdaserviceinfo.com/emazda/dealersystem/service/esi/en_us/SM/2006/Mazda5/ep/books/epd09/html/0914-1a.html
Platinum - Posts: 7,828
Posted: November 10, 2014 at 10:37 AM / IP Logged
Not positive above the Euro models but...
Add a 1000 ohm resistor to your test ground ( earth ) link and hit that same wire that unlocks with a ground..  It should lock.  If that works and your aftermarket system has internal relays for the lock outputs, you should be all set.
shaun wyatt
Member - Posts: 8
Posted: November 10, 2014 at 11:33 AM / IP Logged
Thanks kreg357 i will try that
Thanks Shaun
shaun wyatt
Member - Posts: 8
Posted: November 20, 2014 at 2:29 PM / IP Logged
Hi kreg357 ,i have managed to get the locking working but if i leave the car for about 30 mins it will not open with the remote.You can hear it trying to work.When i open it with the key and close again the remote works fine
Thanks Shaun
Posted: November 20, 2014 at 4:23 PM / IP Logged
Suggest you've taken your power supply from the wrong end of a sleeper circuit, try the constant feed to the ignition switch or fuse box.
shaun wyatt
Member - Posts: 8
Posted: November 20, 2014 at 4:26 PM / IP Logged
Hi Howie, i have taken the live from the window switch,i will try a feed from the ignition or fuse box
Thanks Shaun
shaun wyatt
Member - Posts: 8
Posted: November 20, 2014 at 4:31 PM / IP Logged
Sorry, forgot to mention that i can hear the unit clicking when i try the remote
Posted: November 20, 2014 at 4:35 PM / IP Logged
Window switches are ignition controlled, go back, open a door and wait 30 minutes then test again, bet the wire you've chosen goes dead after a while.
What you can probably here are the internal lock/unlock relays clicking over, tells me poor power supply or earthing point.
Also worth a voltage check between 12V+ constant (which as I said before I believe is your problem) and your earthing point.
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
