2014 lexus i250
mustyk@att.net
Copper - Posts: 132
Posted: November 14, 2014 at 7:21 AM / IP Logged
I am looking for a bypass solution for a 2014 Lexus I250. I tried the ADS version of Omega MDB-ALL with TL-7 firmware and despite their claims IT DOES NOT WORK. Does anybody have a solution that has been tried and true that DOES work?
thetopinstaller
tonanzith
Gold - Posts: 603
Posted: November 14, 2014 at 2:54 PM / IP Logged
If you mean the IS 250 push to start I have used the ads al ca and also the fortin EVO all on these and they have worked just fine.
Gary Sather
Posted: November 14, 2014 at 5:00 PM / IP Logged
Used DB-ALL2 with Python here in the UK on a 2014 LS 600, worked well.
All the equipment was purchased in the US, I didn't need to re-flash the DB, just that everything on the Xpresskit page was the other side of the car.
mustyk@att.net
Copper - Posts: 132
Posted: November 20, 2014 at 7:45 AM / IP Logged
is the LS600 Equivalent to the U.S. made IS250? If so What firmware did you use?
thetopinstaller
Posted: November 20, 2014 at 7:48 AM / IP Logged
No completely different model, it's the large saloon, I was just pointing out that US bought equipment including flashing in the US worked well on a Euro Spec. vehicle thus DB-ALL 2 should give you no problems.
mustyk@att.net
Copper - Posts: 132
Posted: November 20, 2014 at 7:49 AM / IP Logged
Well, gave up on the ADS piece. Would not work, but had better success with the EVO-ALL
thetopinstaller
