2013 Acura RDX
foobarrett
Posted: August 29, 2015 at 9:44 AM / IP Logged Link to Post Post Reply Quote foobarrett
Anyone have stereo wiring info for a 2013 RDX? The factory amplifier is located under the center console, and I see three molex plugs. The smaller one is for ANC. The other two are presumably for audio/power. Trying to figure out colors for input/output so I can wire an aftermarket amplifier.
Thanks!
mleaser
Member - Posts: 18
Posted: September 03, 2015 at 8:26 PM / IP Logged Link to Post Post Reply Quote mleaser
Radio 12V     green     +     radio, gray 17 pin plug, pin 17
Radio Ground     black     -     radio, gray 17 pin plug, pin 9
Radio Ignition     purple     +     radio, gray 17 pin plug, pin 14
Radio Illumination     gray (parking lights), red (dimmer)     +,-     radio, gray 17 pin plug, pins 10 and 1
Factory Amp Turn-on     yellow     +     radio, gray 32 pin plug, pin 23
Power Antenna     black     +     radio, gray 3 pin plug, pin 3
Left Front Speaker (+/-)     blue - pink or white - black     +,-     radio, gray 32 pin plug, pins 24 and 8
The amplifier is in the center console, below the radio. The speaker wires are lt. green - lt. blue at the amplifier, gray 18 pin plug, pins 16 and 7. The tweeter wires are red - white at the amplifier, gray 18 pin plug, pins 17 and 8 (except Technology Package).
Right Front Speaker (+/-)     green - red or red - green     +,-     radio, gray 32 pin plug, pins 26 and 10
The amplifier is in the center console, below the radio. The speaker wires are gray - brown at the amplifier, gray 18 pin plug, pins 15 and 6. The tweeter wires are red - white at the amplifier, gray 18 pin plug, pins 14 and 5 (except Technology Package).
Left Rear Speaker (+/-)     lt. blue - purple or yellow - purple     +,-     radio, gray 32 pin plug, pins 27 and 11
The amplifier is in the center console, below the radio. The speaker wires are yellow - brown at the amplifier, gray 18 pin plug, pins 13 and 4. The rear surround speaker wires are orange - gray at the amplifier, gray 18 pin plug, pins 17 and 8 (Technology Package).
Right Rear Speaker (+/-)     brown - yellow or orange - blue     +,-     radio, gray 32 pin plug, pins 29 and 13
The amplifier is in the center console, below the radio. The speaker wires are blue - orange at the amplifier, gray 18 pin plug, pins 12 and 3. The rear surround speaker wires are yellow - white at the amplifier, gray 18 pin plug, pins 14 and 5 (Technology Package).
Center Channel (+/-)     lt. green - brown (Technology Package)     +,-     radio, gray 32 pin plug, pins 32 and 16
The amplifier is in the center console, below the radio. The speaker wires are pink - purple at the amplifier, gray 18 pin plug, pins 11 and 2 (Technology Package).
Subwoofer (+/-)     blue - pink or pink - lt. blue     +,-     radio, gray 32 pin plug, pins 30 and 14
The amplifier is in the center console, below the radio. The speaker wires are green - red at the amplifier, gray 18 pin plug, pins 10 and 1.
Aux. Audio Input Left (+/-)     black - green (USB, XM audio)     +,-     radio, white 14 pin plug, pins 6 and 14
Aux. Audio Input Right (+/-)     red - white (USB, XM audio)     +,-     radio, white 14 pin plug, pins 5 and 13
