2015 Mitsubishi Outlander Sport Alarm/RS/Stereo Wiring
jgarcia1925
Copper - Posts: 57
Posted: September 06, 2015 at 11:28 AM / IP Logged
Anyone have the wiring diagram for the 15 outlander sport?
I have most of the wiring since Idatalink gives you most but I don't have p lights etc.
Thanks in advance,
Jesus
Also, has anyone done one of these? They seem fairly simple minus the relay to the alarm wire ok the proximity sensor. Is that only for the smart key ones?
tonanzith
Gold - Posts: 603
Posted: October 10, 2015 at 10:23 PM / IP Logged
2015 Mitsubishi Outlander Sport      DirectWire Vehicle Information
All Products
Item     Wire Color     Polarity     Wire Location
12 Volts     BLACK/ red (80A)     +     dash fuse box, black 2 pin plug, pin 1
Second 12 Volts     purple or yellow (10A)     +     ignition switch, white 6 pin plug, pin 1
Starter     lt. blue     +     ignition switch, white 6 pin plug, pin 5
Second Starter     N/A
Ignition     white     +     ignition switch, white 6 pin plug, pin 2
Second Ignition     N/A
Third Ignition     N/A
Accessory     lt. green     +     ignition switch, white 6 pin plug, pin 6
Second Accessory     N/A
Third Accessory     N/A
Keysense     brown     open     key switch, white 7 pin plug, pin 6
Data Bus     N/A
Can Bus High     green (CAN-B); blue (CAN-C)     data     dash fuse box, white 24 pin plug, pins 6, 5
Can Bus Low     red (CAN-B); pink (CAN-C)     data     dash fuse box, white 24 pin plug, pins 7, 4
Can Bus Sw     N/A
Power Lock     purple     -     dash fuse box, white 24 pin plug, pin 2
Power Unlock     white     -     dash fuse box, white 19 pin plug, pin 15
Lock Motor     lt. green     5 wire     dash fuse box, white 19 pin plug, pin 6
Driver Unlock Motor     purple     5 wire     dash fuse box, white 19 pin plug, pin 2
Passenger Unlock Motor     green     5 wire     dash fuse box, white 19 pin plug, pin 5
Parking Lights (-)     (LIN bus)
Parking Lights (+)     yellow (L); pink (R)     +     dash fuse box, white 20 pin plug, pins 10, 13
Hazards     lt. green     -     dash fuse box, white 24 pin plug, pin 19
Turn Signal (Left)     green     +     dash fuse box, white 20 pin plug, pin 18
Turn Signal (Right)     purple     +     dash fuse box, white 20 pin plug, pin 19
Headlight     purple (LO); green (HI)     -     dash fuse box, white 16 pin plug, pins 6, 13
AutoLights     (LIN bus)
Reverse Light     white     +     dash fuse box, white 20 pin plug, pin 2
Left Front Door Trigger     yellow     -     dash fuse box, brown 16 pin plug, pin 16
Right Front Door Trigger     green     -     dash fuse box, brown 16 pin plug, pin 12
Left Rear Door Trigger     red     -     dash fuse box, brown 16 pin plug, pin 7
Right Rear Door Trigger     lt. green     -     dash fuse box, brown 16 pin plug, pin 8
Dome Supervision     yellow     -     dash fuse box, white 6 pin plug, pin 5
Trunk/Hatch Pin     pink     -     dash fuse box, brown 16 pin plug, pin 5
Rear Glass Pin     N/A
Hood Pin     pink     -     dash fuse box, white 16 pin plug, pin 12
Trunk/Hatch Release     brown (rear handle switch)     -     dash fuse box, brown 16 pin plug, pin 14
Trunk Release Motor     green     5 wire     dash fuse box, white 20 pin plug, pin 1
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     (factory remote only)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder and ignition)
Trunk Alarm Shunt     N/A
Tachometer     lt. green, yellow, green, or white     ac     any fuel injector, gray 2 pin plug, pin 2
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     pink     +     clutch switch, white 2 pin plug, pin 2
Fuel Pump     blue     +     dash fuse box, white 2 pin plug, pin 1
Rear Defroster     lt. blue     - latched     dash fuse box, white 24 pin plug, pin 12
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     red     5 wire     left heated seat switch, white 6 pin plug, pin 5
Right Front Heated Seat     purple     5 wire     right heated seat switch, white 6 pin plug, pin 5
Speed Sense     brown     ac     radio, white 20 pin plug, pin 11
Brake Wire     lt. green     +     brake switch, white 4 pin plug, pin 2
Parking Brake     lt. green     -     driver kick, white 18 pin plug, pin 15
Horn Trigger     green     -     dash fuse box, white 19 pin plug, pin 19
Wipers     white     -     dash fuse box, white 24 pin plug, pin 21
Left Front Window (Up/Down)     blue - pink     A     power window main switch, white 16 pin plug, pins 3 - 4
Right Front Window (Up/Down)     lt. blue - green     A     driver kick, white 12 pin plug, pins 6 - 5
Left Rear Window (Up/Down)     white - lt. green     A     driver kick, white 12 pin plug, pins 2 - 1
Right Rear Window (Up/Down)     gray - yellow     A     driver kick, white 12 pin plug, pins 12 - 11
Sun Roof (Open/Close)     green - brown (function with ignition on only)     -     sunshade switch, black 6 pin plug, pins 5 - 6
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     red     +     radio, white 20 pin plug, pin 10
Radio Ground     black     -     radio, white 20 pin plug, pin 20
Radio Ignition     lt. blue     +     radio, white 20 pin plug, pin 1
Radio Illumination     blue (parking lights); pink (dimmer)     +,-     radio, white 20 pin plug, pins 9, 19
Factory Amp Turn-on     lt. blue     +     radio, white 18 pin plug, pin 8
Power Antenna     pink     +     radio, white 20 pin plug, pin 14
Left Front Speaker (+/-)     white - black     +,-     radio, white 20 pin plug, pins 8 - 18
     On models with amplifier, the speaker wires are purple - blue at the amplifier under passenger seat, white 18 pin plug, pins 8 - 18. The tweeter wires are brown - yellow at the amplifier, white 14 pin plug, pins 5 - 13.
Right Front Speaker (+/-)     red - green     +,-     radio, white 20 pin plug, pins 6 - 16
     On models with amplifier, the speaker wires are yellow - brown at the amplifier under passenger seat, white 18 pin plug, pins 7 - 17. The tweeter wires are yellow - blue at the amplifier, white 14 pin plug, pins 2 - 8.
Left Rear Speaker (+/-)     brown - yellow     +,-     radio, white 20 pin plug, pins 7 - 17
     On models with amplifier, the speaker wires are green - red at the amplifier under passenger seat, white 14 pin plug, pins 6 - 14.
Right Rear Speaker (+/-)     blue - lt. green     +,-     radio, white 20 pin plug, pins 5 - 15
     On models with amplifier, the speaker wires are purple - pink at the amplifier under passenger seat, white 14 pin plug, pins 1 - 7.
Center Channel (+/-)     N/A
Subwoofer (+/-)     green - pink (1); white - gray (2)     +,-     amplifier under passenger seat, white 18 pin plg, pins 1 - 9; 2 - 10
Aux. Audio Input Left (+/-)     N/A
Aux. Audio Input Right (+/-)     N/A
RSE Video (+/-)     white - gray (rear view camera video)     +,-     radio, gray 8 pin plug, pins 6 - 7
RSE Audio Left (+/-)     black - gray (USB audio)     +,-     radio, white 18 pin plug, pins 4 - 12
RSE Audio Right (+/-)     white - gray (USB audio)     +,-     radio, white 18 pin plug, pins 3 - 12
Satellite Radio 12 Volts     purple     +     Sat Radio behind glove box, wht 14 pin plug, pin 1
Satellite Radio Ground     black     -     Sat Radio behind glove box, wht 14 pin plug, pin 8
Satellite Radio Ignition     (CAN-B)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     red - green     +,-     Satellite Radio, white 14 pin plug, pins 6 - 7
Satellite Audio Right (+/-)     black - green     +,-     Satellite Radio, white 14 pin plug, pins 14 - 7
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6.3 left front door
Left Front Tweeter     1.4 left front door
Right Front Speaker     6.3 right front door
Right Front Tweeter     1.4 right front door
Left Rear Speaker     6.3 left rear door
Left Rear Tweeter     N/A
Right Rear Speaker     6.3 right rear door
Right Rear Tweeter     N/A
Center Channel     N/A
Subwoofer     9.8 right rear quarter panel
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   behind glove box
Gary Sather
badguyski
Posted: September 19, 2016 at 7:36 PM / IP Logged
Thanks 8)
Ski's Car Audio
abejenar
Posted: January 09, 2017 at 3:44 PM / IP Logged
Hello,
Would you happen to have the wiring diagram for a 2016 Outlander (2014+ works). I need to install a NAV unit and require the stereo wires, back up camera, reverse signal, parking brake and vehicle speed sensor.
Much apprecaited!
