2002 Mercury Mountaineer Alarm/Remote Start/Stereo Wiring
Chris bern
Member - Posts: 6
Posted: May 24, 2003 at 3:41 PM / IP Logged
Hi  I will be installing an alarm and stereo in my 2002 mercury mountaineer and i am looking for a wiring diagram for the vehicle. Any helpm would be much appreciated.
Thank you... Chris B
chris b
Platinum - Posts: 12,488
Posted: May 24, 2003 at 4:42 PM / IP Logged
|              12V|yellow              |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|        ACCESSORY|GREEN/ lt. green     |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |-  |driver kick panel or CSM *1 |
|     POWER UNLOCK|pink/lt. green *4   |-  |driver kick panel or CSM *1 |
|       LOCK MOTOR|pink/black          |   |driver kick panel or CSM *1 |
|     UNLOCK MOTOR|RED / orange          |   |driver kick panel or CSM *1 |
|    DISARM DEFEAT|pink/orange         |   |driver "B" pillar or CSM *1 |
| PARKING LIGHTS +|brown               |   |headlight sw or driver kick |
|       HEADLIGHTS|RED / yellow          |+  |headlight switch            |
|     DOOR TRIGGER|BLACK/ lt. blue      |+  |driver kick panel           |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|common with doors   |   |                            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|org/lt grn or pur/ye|+  |Central Security Module *1  |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|GREEN/ purple        |-  |driver dr harness or CSM *1 |
|       TACHOMETER|*3                  |   |ignition coil/coil pack     |
|      SPEED SENSE|gray/black          |   |radio or GEM *2             |
|       BRAKE WIRE|tan/red to lt. green|+  |brake pedal switch          |
|     HORN TRIGGER|yellow/lt. green    |-  |steering column or CSM *1   |
|           WIPERS|white(L), blu/org(H)|+  |windshield wiper motor      |
|  LF WINDOW UP/DN|wht/blk - tan/lt blu|A  |driver window switch        |
|  RF WINDOW UP/DN|wht/yel - tan/lt blu|A  |driver kick panel           |
|  LR WINDOW UP/DN|gry/org - yel/lt blu|A  |driver kick panel           |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |driver kick panel           |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|WHITE/ yellow        |+  |radio                       |
|     RADIO GROUND|BLACK/ lt. blue      |-  |radio                       |
|     RADIO SWITCH|BLACK/ pink          |+  |radio                       |
| RADIO ILLUMINATE|RED / black   (dimmer)|+  |radio                       |
|       LF SPEAKER|org/lt grn-lt blu/wh|   |radio                       |
|       RF SPEAKER|wht/lt grn - grn/org|   |radio                       |
|       LR SPEAKER|gry/lt blu - tan/yel|   |radio                       |
|       RR SPEAKER|org/red - brn/pnk   |   |radio                       |
Notes:
NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use TBKII to over-ride during remote start.  *1 The CSM (Central Security Module) is in the passenger side C pillar.  *2 The GEM (Generic Electronic Module) is behind the glove box above the kick panel.  *3 For tach go to one of the ignition coils or coil pack and use the wire that is NOT WHITE/ lt. blue.  *4 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to wake-up the system refer to directfax document #1094.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
